![]() | Home > My Range Rover > wheelchair hoist. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
interesting read greg, looking forward to the pics.. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 ![]() ![]() ![]() |
Hope you get sorted. I'm not too far from Leekbrook but not heard ofLRX services.Will be interesting to hear how you get on . I've always used David Pugh(town and country Landovers Sandbach)Good , knowledgeable and reasonable rates . Pulled me out of a tight spot a few times. Ray |
I see from you signature that you have a 2005 car and that is a bit of a transitional time for electronics , you might ( emfasis might) only be able to lower ALL of your heights . 2008 MY Supercharged
Hi axle, my car is a dec 2004 31st I think, bit confusing on here for folks as always being asked or mistaken for if I have touch screen.
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
gregdav
Hi jaybear, nice to hear from you.
Update. Well it seems, as I have read on here, the indy's and main dealers cannot get access to the software required to lower the ff.
Right, lowered the car with the iid tool, haven't had much time to play but getting the wheelchair in and out easier now, in fact better than the last one. Unfortunately my phone (nokia lumia) doesn't support the app, so I'm in the process of getting my first I phone, I did the lowering on the integrated interface, quite easy really when you get your head around it.
thanks for the update Greg. |
Gregdav
Ok lads, son's moving all this week I am trying to split myself so he doesn't have to have time off work, he got the keys early on a vacant property so the usual curtain rail and such like have to be done.
Here's a few pics of the a frame installation for some who might be interested. The first one shows the forward bracket nearest the back of the rear seats, all the brackets are made from 50 x 50 x 5mm angle iron, and fashioned with a cutting disc.
I used rivnuts 6 in total. There is no access here to the inside of the chassis, so I used 2 pieces of angle, and cut some flat off one edge of the angle and fashioned 2 ears to protrude above for drill holes. You must keep measuring and checking the position of the a frame. I managed to get the a frame about 10mm away from the rear tailgate screen.
Then I welded the ears to the angle, clamped together and drilled through. Another pic shows a different view.
You could weld a plate to the chassis with nuts welded to the rear and holes drilled in chassis to clear, to be honest I've had this fitted 2 years, and it hasn't let me down yet, still as solid as a rock.
The next one to tackle was the main bottom pivot point, a little tricky as this needs to be quite solid, the height is important too. I found a couple of good anchor points, a mixture of nuts and bolts and rivnuts, I managed to fashion a couple of brackets that anchored the side and vertical of the bottom a frame.
I can't remember if I managed to get a backing plate on this one, but access is limited on all.
For some reason I've posted a duplicate pic and can't get to remove it.
Once the a frame is in position, there's the small detail of trimming the interior trim to facilitate the brackets. I used a hacksaw blade to trim most of the parts
