Home > Technical (L322) > HELP NEEDED PLEASE. SUSPENSION
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
can anyone help me please
my suspension is in access hieght and wont lift up. theres no messages on dash
any ideas
tony Current. FFRR Vogue. TD6 Java black.
2009 Mini Cooper JCW in Black
Gone. 2006 Discovery 3
2008 Nissan Navarad40
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
2 x saphire cosworths
Various Mk1 & 2 rs Escorts (when i was young and mad)
Post #392060 17th Jun 2016 6:38pm
Weegie
Have you inadvertently pressed the lock button in the centre of the dash control for raising and lowering? Should have a light in it if you have. John
GAP iiD BT
Post #392064 17th Jun 2016 6:45pm
thegamekeeper
theres no lights on. the top one and the middle one come on for a few seconds when i start the engine then go off and stay off. Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #392066 17th Jun 2016 6:50pm
You could try a battery disconnect but it sounds like a hard fault, in which case you need a code read to find out what's broken... Thumbs Up Pete
Post #392067 17th Jun 2016 7:00pm
thegamekeeper
ile have a better look tomorrow and get back to you. cheers Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #392069 17th Jun 2016 7:12pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I had a similar issue on my L322. Mine would lower to access and come back to normal ride height, but would not go to off road and eventually all the lights weent out on the control knob, but I got no message at all in the dash display at any stage. Mine was basically a failed compressor. I also found that if I rotated the knob to off road height and held it there to try to raise the suspension , the 'up' light came on and I could hear the compressor trying to raise it but failing, nothing happened and when I let go of it, the lights went out again. Mine was trange in that it initially had the power to move it from access to normal height. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #392285 20th Jun 2016 4:03am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Can you hear anything noise wise from the compressor? ie is it trying to do something. THIS WRECKAGE
Post #392288 20th Jun 2016 4:43am
