Home > Maintenance & Mods (L322) > tailgate straps
Page 5 of 6 <123456>
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The joy of a dry climate, Just looked at mine and they could have been fitted yesterday. Very Happy 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #365584 6th Jan 2016 8:19am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
rar110 wrote:
Good ideas there Pete. I will do the same when I receive replacements. How long ago did you order yours? I sent an email an nearly 2 wks ago but no reply yet. Maybe they are still closed for xmas-NY.
Hi thanks Thumbs Up and Happy New Year,
Think I ordered them just before Christmas, took about 2-3 days. Most places here (UK) opened on Monday 4th.
I suspect its the volume of post thats slowed things down. Never had any problems with Duckworths.
Peter
Post #365621 6th Jan 2016 12:04pm
Strider
Ian c2 wrote:
I was thinking of doing the 2010 upgrade to my car .
Is the same rust problem evident on that setup as well ?
Not knowing what the upgrade involves and if it affects usage of these straps I dont know.
Ive come across some build threads on here, so it might be worth a look. If they are used in their present form I would say yes to the rusting eventually taking place.
NB: I did notice that the upper one (on car body) seemed to rust more, perhaps the water running down the gully "wicks" onto the metalwork, hence my use of silicone grease.
Peter
Post #365638 6th Jan 2016 1:47pm
mk1paul
United Kingdom 2015 Range Rover Autobiography SDV8 Causeway Grey
I am going to resurrect this thread!
Just received a new pair of straps from Dan and my bolts are completely rusted.
Anybody got any idea how to get them off without damaging the tailgate?
Cheers
Post #392020 17th Jun 2016 1:08pm
wd40 and they will come off with a screwdriver or molegrips.. ... - .- -.
Post #392021 17th Jun 2016 1:24pm
Gritstoner
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
As a new owner I read this thread with interest and had a look at mine under the rubber cap, just in time I think... The pivots were solid and the fixings were spectacularly corroded. I doused them in Plusgas and ordered some new straps.
One of them was so badly corroded that the Allan key couldn't fit into the hex slot due to corrosion and it was bonded to the pivot. I loosened the fixing by turning the whole pivot and bolt and then had to cut off the strap bit with a small hacksaw and undo the bolt with the remains of the pivot and bearing as one.
I was a bit worried about what state the captive fixing would be in but it was perfect, so just a case of refitting the new ones, smeared in grease under the rubber cup/cover though!
Post #392047 17th Jun 2016 5:16pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Looks like I've just joined a not very exclusive club as my nearside one broke today. I was clambering in and out of the boot having cleaned up the tailgate cover and not wanting to put it back on dirty plastics.
Sickening bang and it was broken where the rust was worst.
Must get the WD on the screws for a while before changing. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #399184 4th Aug 2016 3:28pm
And remember, they don't just break at the ends... one of mine looked like this, with a kink...
Cut the plastic off and....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #399185 4th Aug 2016 3:38pm
V8Noise
Now changed, and with liberal use of silicone and copper grease, should maintain the structure for some time.
Although I bought 2 straps, I only used 1 as the offside one was in perfect condition. I suspect it had been changed fairly recently because it was in fine condition. That one is now also coated in "product" to keep it tip-top. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #400066 11th Aug 2016 5:38am
time to check your straps for wear and rust chaps.. ... - .- -.
Post #447922 15th Aug 2017 11:17am
Mr Tee
So just got new straps delivered from Dan. Old ones have hex bolts, new are proper bolt heads, looks like they are handed with Lr038048 as right hand. Question being one end has a nipple end old ones don’t have this , does it fit on body or gate end? Or do I have the wrong one sent? Thanks in advance
Post #475844 14th Apr 2018 7:21pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
How much are the straps nowadays? Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #475887 15th Apr 2018 9:15am
Mr Tee
£42 for both Shocked
Post #475890 15th Apr 2018 9:35am
rjff
Mr Tee
I think you'll find the nipple is to fit the soft opening kit to the right hand side. Have a look at the pics in this thread.
http://www.fullfatrr.com/forum/post458454.html#458454
It helps damp the tailgate and stops it slamming down. Ours works well. Can be retro-fitted I believe and read somewhere that Dan does the damper kit. Can't find the cost I'm afraid.
Cheers
Richard
Post #475891 15th Apr 2018 9:35am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Cost is here - up to date as of a few days ago !
http://www.fullfatrr.com/forum/topic47088.html Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #475898 15th Apr 2018 10:46am
