![]() | Home > Technical (L322) > 3.6 tdv8 2007 low coolant |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
How much is it losing ?
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
You need to bleed the system properly. Procedure is in the workshop manual in the wiki. But basically you need to open the bleed valve when the engine is running and heater on max. Keep topping up until no air comes out of the bleed screw.
If you have an inspection camera and remove a couple of bits you might be able to see crusting around the oil cooler / filter.
Benner91 Member Since: 17 Oct 2015 Location: Belfast Posts: 87 ![]() ![]() ![]() |
Don't know how much it is using as only discovered low level
I think its somewhere between the 12 and 20 litre mark. Not sure but a surprising amount.
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
The leaking Thermostat does seem to be a very common problem! THIS WRECKAGE |
Strange when I went out to car this morning when cold the level was an inch under the mark when I unscrewed the cap air was released and level went up to correct level
Pressure system... Ed |
Stonehaven Member Since: 25 Oct 2011 Location: Aberdeenshire Posts: 37 ![]() ![]() ![]() |
Mine was leaking at thermostat, did require EGRs off, annoying as they had been replaced just 2k miles before. EGR failure has killed two TDV8 engines locally, mine were showing occasional fault codes so were changed as a precaution at 75k miles.
Thanks for info was it an expensive job
Local LR specialist charged £600 plus VAT but that included supply and fit of a parking sensor on same bill, so I guess £450 ex VAT for the thermostat work - including replacement of thermostat housing itself.
Thanks for info you all have been really helpful
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
We had to change our thermostat housing at 65k as well, we were loosing coolant over 4ish months before reaching the low level. As above shine a torch down near the oil filter if you can see red gunk then thats leaking. |
