Home > Technical (L405) > Battery location?
wealy
Battery location?
Anyone know where the battery is on a 405?
I've read somewhere that there are two??
Post #385499 6th May 2016 7:14am
The main one is under the spare wheel
The accessory one is behind the drivers side panel in the boot - photo here Thumbs Up
Post #385501 6th May 2016 7:22am
wealy
Thanks Alistair. Which one should you plug the ctek onto I wonder? Would it matter?
Post #385509 6th May 2016 8:18am
I think that the one under the spare is the main starting battery and the one in the side panel is an accessory battery.
I assume that when the ignition is off, they are disconnected from each other.
Therefore I would charge the one that is under the spare.
What I did was connect a CTEK adapter to the jump posts in the engine compartment - they both unbolt, so it was easy to fit Thumbs Up
I have an Anderson connector and CTEK charger both connected - the lead on the CTEK is long enough that it sits just behind the headlight (bottom of the picture)
Post #385512 6th May 2016 8:31am
wealy
Whilst cleaning the car at the weekend I decided to have a look for the batteries. I found the one behind the panel on the right hand side of the boot area. I took the spare out to give it a a clean and it is not under the wheel? The compressor is there and there is no room for a battery?
Anyone know?
Post #391488 13th Jun 2016 10:09am
it should be there,
https://www.docdroid.net/us5Gyzd/l405-16-.pdf.html ... - .- -.
Post #391489 13th Jun 2016 10:24am
wealy
Thanks Stan.
It must be a huge battery then, but I couldn't see it? There is not (doesn't look) enough room to get the compressor and the battery in ?
I will have another look!
Post #391491 13th Jun 2016 10:43am
if you have starting problems then maybe someone has nicked it Mr. Green Wink ... - .- -.
Post #391492 13th Jun 2016 10:48am
wealy
They would not nbe able to find it!
Post #391493 13th Jun 2016 10:49am
Laughing ... - .- -.
Post #391494 13th Jun 2016 11:08am
Shocked Did your guide dog have a proper look around Cool It's a big battery ! Wink Thumbs Up
It's raining here - but I might empty the boot & take a photo if it ever stops Whistle
Post #391496 13th Jun 2016 11:16am
Here you go - and yes I know my wheel well could do with a vacuum, but I did empty it & remove the spare wheel just to take the photos....
Ignore the additional cable with the anderson connector on (bottom left) - I added that - I have then on all my cars
I don't think there's a cover - but it is possible that there should be a piece of carpet that should sit on top - in which case, I guess it would be difficult to spot..... Embarassed
The negative terminal is a bit more obvious - even got a handy label on mine -
The positive is a little more discrete -
Post #391511 13th Jun 2016 1:33pm
wealy
Thanks Alistair, there is carpet covering all that on mine. When I get round to it I will have a closer look now I know its there somewhere!
Why do you have Anderson connectors on all your cars? Are you an ex AA man? Smile
Post #391513 13th Jun 2016 2:10pm
I did get the idea from an AA man.... but a few factors - I seemed to get asked for a jump start a lot in my old Jeep, my old L322 would refuse to start whenever it was too cold and I hadn't used it for a while, there were times I needed longer leads, or atleast it was useful to have longer leads - so it was easier just to fit connectors - and once they were on one car, it just seemed to make sense.....
All my cars have connectors fitted.
I have a spare battery with a connector that lives in my garage
I have jump leads in each car with a connector on one end
I can connect the cables together for a much longer cable if I need to
The connection is as close to perfect as you can get - the crocodile clips are not a good connection
It's a much safer, cleaner connection, no sparking or spiky voltages
I've jumped plenty of cars from a FFRR without any issues - despite advice to the contrary - I'm convinced it's down to the quality of the connection.
Having said that, I've also now got a Floureon pack which I would generally use in preference to a direct jump start Thumbs Up
Post #391515 13th Jun 2016 3:17pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Reviving this old post as I'm planning to replace my all leather steering wheel currently fitted with a new piano black / leather wheel at the weekend. As I'll need to disconnect & remove the steering wheel airbag, assuming I'll need to disconnect BOTH batteries to avoid SRS errors?
Post #469592 21st Feb 2018 4:57pm
