Home > Technical (L322) > Instrument Cluster Lights not working, Headlights affected |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
The cluster lights should dim with all the instrument and waterfall lights in the car. Are they all flickering? The current to the lights is controlled by the lcm. Rather than relays, They are transistor drivers. I had one go on mine years ago. I was able to open up the the lcm and see the transistor had burned out. I was also able to read the chip Id and from that find a replacement for about £10, but didn't go any further. I would be a case of in soldering and re soldering the new one onto the board. V8 or else ... |
11th Jun 2016 8:35pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
The LCM ECU can be found in the RH footwell behind the A post lower trim (on UK cars next to the Accelerator Pedal) .
11th Jun 2016 11:22pm |
nip848 Member Since: 26 Mar 2016 Location: London Posts: 29 |
Thanks for the replies fisha & Joe90!
12th Jun 2016 5:51pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Your full beam issue is down the the LH stalk needing replacing... Quite common on early FF's |
12th Jun 2016 11:33pm |
Thanks Craig, so would your thinking be I have two separate issues in this case? One with the indicator stalk for the headlight issue, and one with the LCM for the instrument lights not working?
12th Jun 2016 11:57pm |
I sent the LCM off for repair and its fixed the headlight issues.
4th Jul 2016 12:02pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
When I took my cluster out to have my pixels repaired a while after I started getting faults whereby I wouldn't have any dash lights showing, the indicators wouldn't work or they worked but I didn't have the lights on the dash or the ticking noise.
9th Jul 2016 6:48am |
Thanks Holidaychicken, gave that a go when I had the dash board off to install the wifi revere camera to the head unit. All the connections to the dials seemed fine and gave them a check. Ran the cluster test, still no lights!
1st Aug 2016 1:48pm |
My connections seek=med ok but i removed them and replaced them and that seemed to do the trick. the LCM is prone to getting wet, cant remember but do you have any diagnostics faults ? |
1st Aug 2016 1:58pm |
Ah so you replaced them anyway. Maybe shouldve done that!
1st Aug 2016 2:15pm |
sorry confusing you with a typo as well, i disconnected them and reconnected them which may have done the trick, they certainly worked ok after. so the part numbers are free.
1st Aug 2016 3:24pm |
