Home > Technical (L322) > Trans failsafe mode
ian
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
Trans failsafe mode
HI all
Well once again failure has struck.
After about 15 min driving I suddenly had the failsafe message come up. The only way I could get any drive was to switch he engine off, wait a few minutes then restart and go, only for within about 30 seconds for all drive to vanish. There are no sudden clunks or bangs, it's as though the drive just fades out. Has anybody else come across these problems, as I am lost as to where to start.
It is a td6 02 plate, engine always starts fine. I know it seems obvious to suspect the gearbox, but have seen it suggested that such things as a plug or coil failing, maf sensor going or O2 sensor. Can anyone help as having one of those weeks
Satrted with a job at 8k being dropped to 1700,
Then rained all day and mower died
Then trailer was stolen
Got areola ement trailer after a 400 mile drive
Only to find a brake cable was seized and also someone had badly adjusted the brakes and burnt out a set of of shoes so they had to be elated
Then broke the s reen on my phone
Now the range has decided to get in on the act as well!
Any help greatly appreciated
Post #390935 9th Jun 2016 5:12pm
Very common, use the search box, loads about it... it will be the box, and not good news I fear.... Big Cry Pete
Post #390957 9th Jun 2016 7:07pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi ian, I'm afraid you need to get the fault codes read.
There are no plugs, coils or o2 sensors on a diesel.
Mine went the same, loss of drive, or similarly like a slipping clutch, fortunately I managed to pull in to a car park and awaited the breakdown truck.
A rebuild gearbox, including tc, solenoid valves and accumulator springs, the gm g/box is well noted for these problems.
Let us know, how you get on.
hope this helps.
greg Thumbs Up
Post #390959 9th Jun 2016 7:14pm
ian
Thanks all
Anyone want to buy a red vogue td6 with knackered gearbox?
Post #390965 9th Jun 2016 7:39pm
£1000... Pete
Post #390967 9th Jun 2016 7:43pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
sorry to hear of all the bad things happening this week pal, keep your chin up things have to get better.
What's your battery like mate as it seems the most common cause of the failsafe mode is the battery struggling? Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #391003 10th Jun 2016 6:41am
Not usually when you lose drive as well Danny... Thumbs Up Pete
Post #391005 10th Jun 2016 7:18am
DannyH
must've missed that Pete, sorry pal. Dan
2002 Zambezi Silver
Post #391501 13th Jun 2016 11:56am
