Home > Technical (L322) > HDC SUSPESION AND ABS LIGHTS AGAIN |
Digger7820 Member Since: 04 Jan 2016 Location: Brigg Posts: 28 |
Ok here's another part of the sarga!
8th Jun 2016 9:03am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8283 |
Sorry about yesterday Graham, couldn't be helped, I'll text you in a minute, what you describe is pretty normal, they self level after you stop, sometimes before you get out but if you are quick with the door they wait until you have got out.... Pete
8th Jun 2016 9:16am |
Had Graham pop over this morning, quick plug in of the IID and confirmed it is the steering angle sensor on the bottom of the rack, live values show it is totally worn out... two ECU's throwing up steering angle fault so at least he knows what direction to follow, unlike his FF.....
9th Jun 2016 11:37am |
Hi
9th Jun 2016 12:26pm |
Ok finally got the steering angle fitted and Pete was correct, it can be fitted with out removing the dash it took about an hour to do the job. Land Rover estimate 8 hrs
15th Jun 2016 6:07am |
Good job... Pete
15th Jun 2016 1:16pm |
so that's the end of that saga!
15th Jun 2016 4:16pm |
