Home > Technical (L322) > Air conditioning leak
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I thought i would add my experience to the search engine so it may help others in the future.
After my air con went warm i contact a mobile guy for a re gas.
He duly turned up, supposedly pressure tested it, and re gassed with dye.
It lasted all of one hour and i called them to ask for a leak detection.
A week later he came back and after a while said it was coming from the compressor area but said he was unable to help any further.
He recommended a place in North London and said be prepared for a bill of £1500 as everything needed to be stripped for access.
I booked it into a local LR indy that i've never used before expecting the worst.
After his own diagnosis he called to say a hose had split near a bracket and it will be around £200 plus re gas.
Thats more like it!!
Post #389995 3rd Jun 2016 9:34am
Clivefog
If the hose was split on vacuum down then it would have shown up then. I would not use him again.
Post #390327 5th Jun 2016 8:51pm
PaulB
They showed me the pipe, it was the one you suggested.
They said you could hear the leak it was so bad.
The original mobile guy had good reviews on this site!!
Post #390329 5th Jun 2016 9:48pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
I don't see any "hoses" on my system. The pipes are all metal. I wouldn't have thought that a rubber hose could cope with the pressures involved.
I guess these things get lost in translation sometimes though.
Post #392230 19th Jun 2016 9:16am
PaulB
You are correct, it was a metal pipe.
Post #392248 19th Jun 2016 5:10pm
