Home > Maintenance & Mods (L322) > REAR WHEEL ARCHES - Look After
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Summers here and a job I have been meaning to do for a couple of months
Hammerite Black the inside & outside of the rear wheel arches.
Easy to do - I had very small rust dots appearing - now sorted
Very easy to do - just allow 5 very thin coats allow to dry ( 45 mins in warm weather ) - build up the coats - spray inside as well as out side
Masking tape makes a clear line and the finished job is 100% mint
Should last a few winter years more
Hope this gives you ideas.
Post #389905 2nd Jun 2016 8:09pm
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
good call but what years your fatty ? mines 2004 and all arches are mint tbh 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #389907 2nd Jun 2016 8:16pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Once you've done this, I added a rubber u section trim to the welded arch joint ( I coated in petroleum jelly first). Available from Dan LR001623 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #389909 2nd Jun 2016 8:20pm
EmiratesA380
Hey boatsandy1966
Ours are 12 MY - we do live in the countryside having said that this one is only used on the Motorways back and forth - so shes had a life of 70 MPH ( and some ) - Wheel arches are washed every day during winter months - so there's no problem with salt - The ARCHES are usually cleaner then the windscreen
Thanks for posting reply
Post #389910 2nd Jun 2016 8:20pm
EmiratesA380
Hi paulmoran2
I was letting these dry for 24 hrs - then I was going to seek out some Dum Dum - Black rubber to paste coat the inner's
https://sugru.com/great-for/cars-and-motorbikes
Its now called SUGRU
Hope this helps with ideas
Post #389911 2nd Jun 2016 8:25pm
boatsandy1966
dam wish I had time to wash mine daily also in country and on beach daily but no rust at all maybe ive been lucky with paintwork Razz 1937 model y hot rod 1000bhp rover75 v8 vincert blackshadow plus several boats and other toyz ! ford f150 raptor Mercedes e class convertible jaguar f pace
Post #389912 2nd Jun 2016 8:30pm
mr_spock
Dum Dum and Sugru are not the same. Dum Dum (no longer made) is a soft sealant that stays soft forever. Sugru is a moldable semi-flexible plastic that is very soft when applied but cures in air to go fairly hard.
Post #389959 3rd Jun 2016 7:35am
pld118
An observation. Some people say the original LR rubber strips have metal inside that can contribute to corrosion. On forum member ndf recommendation, I've used this method on 2 L322 now and it works very well.
http://www.fullfatrr.com/forum/topic22530.html?highlight=strip
Post #390038 3rd Jun 2016 11:03am
EmiratesA380
pld118 - SPOT ON - well said
Post #390048 3rd Jun 2016 11:22am
