Home > Technical (L322) > Which code reader
Mart67
2005 Range Rover Supercharged 4.2 SC V8 Java Black
Which code reader
Hi there, what code readers are you guys using. I want to get one but want a decent one that works with the l322. I have a 2005 SC full fat.
Cheers
Post #389815 2nd Jun 2016 11:32am
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Mart, welcome to the forum!
It is well documented accross the forum that the GAP IIDTool is the best ODB code reader for the FFRR's.
More infor can be found here:https://www.gap-diagnostic.com/products/iidtool/
You can occasionally find one in our for sale section of the forum Thumbs Up
Good luck. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #389821 2nd Jun 2016 11:42am
+1 as above, the GAP iidtool... ... - .- -.
Post #389826 2nd Jun 2016 12:03pm
Realist
Wales
GAP hands down. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #389827 2nd Jun 2016 12:05pm
Lost for Words
IID BT. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #389830 2nd Jun 2016 12:20pm
If you don't go gap and decide on a cheaper one which claims to read ALL the codes, make sure they have a return policy as a lot that say they will, won't... Rolling Eyes
The IID is undoubtedly the best out there but is not cheap, one good thing is that you will get a lot of your money back when you sell the car as second hand prices are strong... Thumbs Up Thumbs Up Pete
Post #389839 2nd Jun 2016 12:48pm
mr_spock
I have an iCarsoft i930. It seems to read all the codes, it's make for the Land Rover range. You can interrogate all systems, or just the one you want, you can view live data and clear errors. Unlike the IID, you can't set custom parameters. It was £90 ish, and does what I need. It's not locked to a vehicle and is also a generic OBDII reader for any other (modern) vehicle.
I need a code reader for my Series 3 Landy. I think it just needs to be able to suck through it's teeth and order parts.
Post #389872 2nd Jun 2016 5:52pm
Without doubt the Gap IIDTool. Nothing comes close at the price and the support from the guys is legendary in these here parts. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #389873 2nd Jun 2016 6:08pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I also have the icarsoft i930. Price was the main issue for me and being able to use on any Land Rover or Jag with no vin lock. I got mine for 80 pounds on offer. I can only say it has been super useful on my L322 and a mates Disco 2. Seems to cover everything and is updatable foc but is limited to reading and erasing errors plus live data. It cant change any parameters but thats not a major issue. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #389990 3rd Jun 2016 10:27am
Weegie
The Gap iiD BT is not VIN locked for reading and erasing recorded faults. John
GAP iiD BT-Sold
Post #389992 3rd Jun 2016 10:30am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I'm with Mr_spock on this one.
When I first got my L323, I was on a budget, and as far as getting it going I needed to view the codes in the air suspension and work out why it stayed inactive!
Bought the iCarSoft for £99, picked it up the same day from Oxford, with in twenty minutes my air suspension was running flawlessly! Turned out the compressor had been unplugged, and a height sensor had been changed and just needed a re set!
I do plan to get an iid tool when the Mrs is off Maternity leave, but for the price it cost me is roughly the same as a trip to the dealer, plus I'm covered until I upgrade it!
Post #390148 4th Jun 2016 1:29am
mogman50
England 2008 Range Rover Vogue SE TDV8 Tonga Green
Quick question. Will the icarsoft tool reset the service indicator on a L322.
Thanks. Paul
Post #390153 4th Jun 2016 8:20am
Stacker
As far as I know, on my 2003 L323 it's a few button presses to reset... May be wrong but worked on my car
Post #390155 4th Jun 2016 8:38am
steadyaway
I too have the icarsoft i930. I also have an Autel MD802 all system reader. This is useful for other cars in the family and I occasionally use it (for donations) for work colleagues. The advantage over the i930 is that ir will read TPMS if fitted. The amount of info it returns about the full fat is unbelievable.
Post #390442 6th Jun 2016 8:42pm
Rob99
Most vehicles with electronic digital mileometer's will have a way to reset the service counter. As Stacker says, it's usually a few button presses. Probably says in the manual or, if like me you can never find it when you need it, just google it. Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #390448 6th Jun 2016 9:10pm
