![]() | Home > Technical (L322) > Odd Gearbox Symptom 03 V8 Petrol V8 or poss Diff |
Wylie66 Member Since: 10 Jan 2016 Location: Bushey Posts: 67 ![]() ![]() ![]() |
I have done some cursory searching but wondered if someone can give a quick answer.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Clutch engagement issues which are 1) fluid temperature dependent and 2) engine speed dependent usually indicate a leak in the hydraulic circuit somewhere. For the ZF 5HP24 transmission clutches C & F are used for reverse and neither of these clutches are used in any of the forward gears.
Thanks for the prompt responses.
If you’re getting overrun braking in manual mode in 1st gear then it sounds like a C clutch issue. Could possibly be the O-rings on the D/E clutch drum support bush or worn phosphor-bronze bushes in the sun gear sleeve, both of which act as seals for the C clutch hydraulic activation circuit.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8531 ![]() ![]() ![]() |
Diffs can't have anything to do with it, if it doesn't engage reverse, a nasty clonk when it was engaged could be the diff...
Superb info, thanks guys.. I see what RRPhil meant by leakage now.. my naive mind was thinking they fixed leak but he meant leakage past seal. I will call transmission place and get their take on it. is it a hard job to replace the C clutch? 2003 V8 Vogue in Silver |
If I were them I’d drop the sump and the valve body assembly and apply air pressure to the C clutch to check for leaks before going to the trouble of taking the transmission out. Unfortunately the seals/bushes we discussed are buried quite deep within the transmission so the whole thing would have to be stripped to get at them.
