Home > Technical (L322) > Rough Idle when warming up - 2007 3.6TDV8
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
When the car is cold (typically having been left overnight), it is absolutely fine. When it is up to temperature, it is absolutely fine. When it is neither, it idles extremely roughly to the extent that the car shakes. It is worse in Drive than in Park or Neutral. As soon as you apply power, it settles down.
I've had it to my specialist. The hoses are fine and there are no fault codes showing up. I don't want to start changing parts at random so I'd appreciate any thoughts, please.
2007 3.6TDV8 with 72000 miles. 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #389573 31st May 2016 7:47pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
what diesel you using mine used to have rough idle when cold on any fuel other than shell ultimate L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #389577 31st May 2016 8:00pm
JW911
Standard stuff (mainly Asda). Embarassed
A few tanks of V-Power then? 2012 4.4 TDV8 Westminster
Post #389578 31st May 2016 8:02pm
Ivor
try a tank of the good stuff it may solve it L322 2008 vogue
Post #389674 1st Jun 2016 11:30am
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
check the live data and compare the readings from the left bank and the right, they should be pretty close to each other at all times
one reading being quite different (but not enough to ping up a code) could help you find the answer
could be a sticky EGR?
Post #389842 2nd Jun 2016 12:09pm
JW911
Good guess. Thumbs Up
This had been ongoing for about a year with no fault codes and getting progressively worse. It finally threw one up.
It was nothing £1000 and two new EGRs wouldn't fix. In fairness, only one had failed but I had them both done while it was all apart. All now sorted. 2012 4.4 TDV8 Westminster
Post #400448 13th Aug 2016 11:52pm
