Home > Technical (L322) > Rear Near Side brakes binding
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Hi guys,
My near side rear brake is binding and the alloy wheel is very hot to touch with the normal train station brake smell! Any ideas on what I can do to enable me to drive the car without overheating the discs/wheel?
The weird thing is I can move the car when off in neutral so the disc doesn't seem to be completely seized..
Grateful for any thoughts. Should I not drive in the meantime?
Regards
Jase
2006 Vogue 3.6 V8
Post #389137 28th May 2016 8:26pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
depends how handy you are with spanners you can either remove the wheel and then the caliper and use grips to push the pistons back in and then put the caliper back on and operate the brake repeat a couple of times to see if it fixes the problem if not you either need a rebuild kit or new caliper or if you are not that handy get a mobile mechanic to do it either way you can't drive it L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #389140 28th May 2016 8:49pm
Jase71
Thanks Ivor..
I tried pushing the car in the drive in neutral and it was fine so went out for a drive and after I braked at 60 mph I got a lot of vibration and then driving slowly I could here a scraping noise on the near side rear wheel accompanied by a nasty hot brake smell. So my drive out was abandoned and my FF is now back at LR!
What annoys me is I had front discs and pads done last month and you think they would have checked the rear!
Of course on a long weekend so now the wait for a fix and the resultant damage to wallet!!
Post #389433 30th May 2016 7:06pm
Ivor
Just replaced all my discs and rear pads last weekend that was fun saved me a fortune on parts and labour my local up here give me a free check over once a year to try and get work lol the girls know I do my own apart from servicing L322 2008 vogue
Post #389454 30th May 2016 9:24pm
Jase71
Okay, calliper was locked on...two new rear discs a calliper and pads! £££
Post #389724 1st Jun 2016 5:48pm
Ivor
I picked mine up for around £60 for the discs and about the same for the pads easy enough job just the handbrake adjuster is a pain to see L322 2008 vogue
Post #389775 1st Jun 2016 10:13pm
Time to talk to Dan Thumbs Up
Common problem & worth doing both sides. When I did mine, I got a very good price from Dan - callipers on an exchange basis
Post #389795 2nd Jun 2016 8:24am
ebajema
The rear calipers are a weak point on the FFRR and usually go close together, so good choice to replace both, pity that you had to do it so shortly after discs and pads though. Hope that you will have many more problem free miles. MY 2010 5.0 SC Galway green and sand interior!!
Post #389825 2nd Jun 2016 10:58am
