Home > Maintenance & Mods (L322) > Axle Stands - how to take 2 wheels off?
pld118
Hi, I want to take 2 wheels off at once. I've only used the axle stands to take one at a time off until now. It's fine and stable jacking one wheel up, putting an axle stand under and removing the wheel but if I then jack up the other wheel, it looks like the axle stand supporting the opposite corner would then become unstable.
is it best just using them for one corner at a time or does anyone have any tips please?
Thanks.
Post #389194 29th May 2016 11:16am
First make sure they are decent sized axle stands, I would say at least 2 1/2 ton ones, if you can, jack the whole front or whole rear at the same time, either under the front of the engine cradle where the tow point is, or under the tow bar or the rear subframe, if you cant then jack one side to the lowest height possible, which is around 3" of air under the wheel, as you jack the other side the first side will drop somewhat, then just have faith and jack, ensure the wheels of the jack can move as you jack and the car should raise and pivot on the first stand rather than dragging the first stand...
Take it easy and it should be fine, I do it all the time.... obviously don't take the wheels of until it is fully jacked up and supported... Thumbs Up Thumbs Up Pete
Post #389208 29th May 2016 2:21pm
Don't recommend trying to jack up two opposite corners!
If you do need that, suggest you jack the whole car up. May need more axle stands or decent wood blocks (short sleepers etc)
As Pete, says......don't take any wheels off until everything is up and safe, I generally double up and have extra wood blocks underneath even though I have the axle stands in place. .
Post #389211 29th May 2016 2:30pm
johnboyairey
you'll be fine.....
Post #389268 29th May 2016 10:44pm
Rob99
Do you think there is a market there for the exact length supports for each model of pick up truck Rolling with laughter Rolling with laughter
Post #389273 29th May 2016 10:53pm
Laughing Laughing Laughing Thumbs Up
Post #389275 29th May 2016 10:58pm
johnboyairey
...at least the second guy is safe.... he's unwound all the cable off his extension reel, -you don't want to start a fire ...under the fuel tank... do you?
Post #389279 29th May 2016 11:36pm
pld118
Thanks for the replies... Maybe my description but I did mean taking both wheels off the one axle at once as opposed to taking off the front and back wheels on the same side of the car. Won't be taking any wheels off this BH weekend though as the time has passed me by Rolling Eyes
Post #389306 30th May 2016 8:43am
Make sure the car is in Park and the Handbrake firmly applied and you have wheel chocks in use! I have some old driveway bricks i use as chocks as they haven't failed me yet and dig in quite well as i test by trying to drive over them in low box Smile
Park should be a proviso as most FF's wont let you take the key out without it being in park either but the handbrakes arent the best in the world Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #389475 31st May 2016 8:15am
Weegie
This might help:
http://workshop-manuals.com/landrover/l322...g/lifting/ John
GAP iiD BT
Post #389476 31st May 2016 8:20am
Draper Expert 6 tonne stands. The are one of the few Draper products I can recommend as I'm not a Draper fan, but these really are the bogs dollocks.
Not cheap but what price safety
Post #389619 1st Jun 2016 6:51am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
For the rear wheels I made a Heath Robinson spacer block to stick on my 3T low access workshop jack (from SGS) to fit between the exhausts onto the suggested jacking point on the rear cross member.
I'll snap a pic if it's any use?
For the front there is already a flat section on the cross member if you remove the plastic tray section on the front sub frame.
That way it's possible to lift the entire end of the car off the floor without too much effort (again, caveat being usual chocks, good ground, and decent jack, but you knew all that so sorry if excessively patronising!)
IIRC these jacking points are the ones mentioned in the WSM (and probably elsewhere in this thread)
Cheers
Stephen Formerly happymadison1978
Post #389770 1st Jun 2016 9:53pm
fattobes
Sweden 2011 Range Rover Vogue SE TDV8 Fuji White
sorry, rather a newbie question on this topic.
In order to jack from the front to get both front wheels off the ground at the same time, do i have to remove the plastic tray under the front (sub frame?)? i.e. i can't access the point that haylands mentions just by the jacking point without first removing the plastic.
i searched around with a torch tonight but i couldn't figure it out.
thx 2011 4.4 TDV8 Vogue SE Fuji White
2002 4.4 Vogue Java Black - Gone
2002 4.4 Vogue Epsom Green - Gone
Post #408868 11th Oct 2016 8:10pm
Big Boy R44ROV
Mine currently is on two 3 tonne axle stands, (6 tonne total) whilst the upper arms are being replaced (the benefits of a son who's a mechanic) i'll take some photos in the morning, but they have been placed on the jacking points and lifted initially using a 3 tonne trolley jack. I'll do a set of how to do photos now! Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #408869 11th Oct 2016 8:17pm
