Home > Technical (L405) > Fuel Sloshing
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
Fuel Sloshing
I have an MY16.5 and when the tank is half empty I can hear thumping in the back under slow maneuvering, after having a proper listen it appears to be fuel sloshing around. Having had a search it appears this was a problem affecting early cars and was resolved by a TSB (assuming an updated baffle design), I am surprised it still remains 3yrs on. Last time I had this issue on a car was nearly 10yrs ago on a Honda Civic with a fuel tank under the front passenger seats.
Has anyone else experienced this before I take it into the dealer? 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #388729 26th May 2016 9:58am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
I had the same noise with my sept. 2016 build. Had it in a couple of weeks ago for rectification. All ok now but surprised it's not done at source. It's a foam baffle they install by the way. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #388750 26th May 2016 11:09am
JamesD
Thanks, did you have to argue for it or did they accept straight away? 2021 L405 Vogue D300
Post #388798 26th May 2016 3:01pm
Pfazz
No arguments. I'm pretty sure there is a service bulletin on the subject. They kept it over night though. Agueroooooooooo. 93-20
Post #388801 26th May 2016 3:05pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Well known fault. It affects both L405 and L494 on all model years.
I asked a senior manager at LR why they won't do it at the factory and apparently it's because the process is too manual.
It's foam baffles that they fit.
Post #388828 26th May 2016 6:58pm
