Home > Technical (L322) > TDV8 Engines. Are they the same?
theanswers
Ireland
Hey Guys. Is the TDv8 Engine in the sport the same as the one in the Full Fat.
I think they are but just want to confirm.
Thanks. Thumbs Up
Post #388717 26th May 2016 9:27am
Lost for Words
Yup. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #388718 26th May 2016 9:56am
Of a certain age..... the Sport only had the 3.6, the FFRR moved on to the 4.4
Post #388723 26th May 2016 10:22am
theanswers
Ireland
Cheers lads! That's all the info I need. Hopefully will get an engine sorted soon! Very Happy
Post #388724 26th May 2016 10:27am
I would be very surprised if the engines were the same 3.6 unit in both cars! They certainly run different ancillaries.
I would imagine the block has the same casting! But as in most cases, there will be many many differences between the 322 & 320 running the 3.6TDV8... Rolling Eyes
Post #388725 26th May 2016 10:30am
theanswers
Ireland
Would a lot of that be bolt on items? Could I bolt my various additional components on.
Post #388726 26th May 2016 10:34am
If your after a 322 replacement... I would think a 322 replacement is what you need sir... A 320 engine could mean changing heads and every sensor etc etc over between engines! That becomes VERY expensive! Let alone finding your engine may have tapped holes a 320 engine does not???
The fitting kits for the injectors for example are now around £400 Shocked
Worth asking around further before buying one sir Bow down
Post #388727 26th May 2016 10:37am
theanswers
Ireland
That rules out the Sports so! I'll have to keep hunting. It's hard work! Sad
Post #388728 26th May 2016 10:40am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
If you're really stuck, I do have a contact who might be able to help, a recently retired GM for a rather large salvage operation, there is an outside chance at best, happy to call him.
Post #388743 26th May 2016 11:35am
GraemeS
Australia
According to my copy of MCAT the 3.6 blocks, heads and inlet manifolds in the L320 and L322 have the same part numbers. Obviously the sump is different.
Post #388755 26th May 2016 12:42pm
Mikey
Basic engine is the same, sump, wiring and ancillaries are all different
Post #388757 26th May 2016 12:52pm
theanswers
Ireland
Hey Mr. Tee, That would be great. I could PM you my mobile and you could chat me first if you like?
I missed out on the Sport Engine, but no harm! Just really want to get this RR back on the road. It's been off nearly two months and between being scammed etc, it really beginning to get tedious at this stage!
Again thanks for your input everyone!
Post #388854 26th May 2016 10:41pm
Mr Tee
Aye, go for it, he might be abroad just now, can only ask.
Post #388857 26th May 2016 11:08pm
