Home > Maintenance & Mods (L322) > Transfer case and diff oils
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Would someone mind clarifying what oils are required for the diffs and transfer case, please?
I checked the wiki, but the 3.6 is listed
http://www.fullfatrr.com/wiki/Recommended_Lubricants
Is it the same oils as the 4.2 supercharged?
Just wanna check
Cheers
Post #388558 25th May 2016 8:14am
its in the WM and it shows how to do it as well.. ... - .- -.
Post #388560 25th May 2016 8:34am
cheezels
Ok, I didn't see it.
I'll check again
Post #388562 25th May 2016 8:48am
cheezels
Found it.
SAF XO
Has Syntrax Long Life replaced SAF XO?
SAF XO doesn't seem to be available in 'Straya
Post #388577 25th May 2016 10:53am
