Home > Off Topic > Domestic house electrics
Realist
Wales
The below is more than efficient to cover your needs but again part P comes into play and would advise a on site check by a part P electrician to sign off the work.
Its covering your arse at the end of the day.
IanT599 wrote:
Cable run is approx 8-10metres.
I've thought of running a 10mm cable direct form the main consumer unit to the welder. Running through joists and clipped to them to the attached garage. Last 2m in conduit.
Got a 32A socket for it for the garage. Worst case is if the welder I get is 16A or smaller then change to socket as required.
Got a 40A type c rcbo for it for the main consumer unit. 10mm cable is rated as 63A clipped and 52A in conduit so more than sufficient.
Going to run a second 10mm cable direct clipped and through joist but no conduit to the garage consumer unit.
RCBO type b 50A on the main unit feeding the garage unit.
Got a 16A socket for the caravan to fit too now as arrived.
 Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #387852 19th May 2016 1:05pm
