Home > Technical (L322) > l322 outside ambient air temp sensor wiring???
fullfatbob
England 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Can anyone help?
As I work through a list of bits and bobs to fix on Monty...I purchased a new air sensor...bargain by the way..£2.99!!
http://www.ebay.co.uk/itm/400442665350?_tr...EBIDX%3AIT
Anyway..unbolted grill...old sensor still in place..no wiring..hunted around and just could not find it...so puzzled as why it is missing...however can anyone tell me where it plugs into..so I can if all else fails try and get a new lead.
Thanks Thumbs Up
Post #387655 18th May 2016 10:53am
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Funnily enough I had my outside temp failing to record at the weekend. Whipped the grille off and found the two core wire to the sensor had come into contact with the fan which had chopped a bit out of one core of the twin core wire. Soldered the wires together and insulated with shrink wrap. It works fine. 15 minute job so easy fix. The wires run behind the n/s front panel on my rhd tdv8. Hope this helps. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #387839 19th May 2016 1:05pm
fullfatbob
Thanks...if the sun shines this weekend, I will have another look to find the missing wires...thanks again for the tip!
Post #387877 19th May 2016 3:57pm
