Home > Technical (L322) > Bank 1 and Bank 2
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Bank 1 and Bank 2
Which set of cylinder's is classed as bank 1 and which set of cylinder's is classed as bank 2 ?...
Range rover TDV8 2007 ??..
Post #387745 18th May 2016 7:39pm
sako243
I know the driver's side is labeled 1234 from front to rear. Right is 5678 front to back.
So one would assume bank 1 is left?! Ed
Post #387755 18th May 2016 9:17pm
STU TDV8
Yeah they were my thought's too..
Post #387757 18th May 2016 9:21pm
sako243
Any particular reason? I've always heard them referred as LH and RH. Ed
Post #387763 18th May 2016 9:36pm
STU TDV8
Yeah my turbo actuator has gone and it give the bank number so need to know which side to look at ?.
Post #387764 18th May 2016 9:41pm
sako243
I've found the workshop manual PDF (available via the Wiki) to be very useful. If you look in the relevant section there's normally a table of DTC codes with a diagnosis / debug procedure along side.
Perhaps if you look up those then it will tell you which side it's meant to be on. Ed
Post #387808 19th May 2016 9:20am
