Home > Maintenance & Mods (L322) > TDV8 servicing
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
TDV8 servicing
Sorry if this has been asked before, but I'm not having much luck with the search function.
I realise there is a filter service A and B, basically yearly, but what other maintenance items are there?
I used to have a landrover 'issue' service checklist when I had a D3. Mentioned various checks, oil changes at certain klms, belt changes, brake fluid etc etc.
Does the Range Rover have such a cheat sheet?
Post #387200 15th May 2016 9:54am
cheezels
Bump
Razz
Post #387278 15th May 2016 11:59pm
rar110
Gday Steve
I've never found one specifically for the TDV8 3.6. My mechanic seems to do the following:
• oil, oil filter and air filter every 10,000 km;
• fuel filter and pollen filter every 20-30,000km.
The belts are as required I think. The coolant and brake fluid is a standard time thing as far as I know. 3 years comes to mind.
Regards
Pete ______________________________
Post #387426 16th May 2016 10:30pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Cheezels
Are these any help to you:
Ive done them is 3 parts so you can print out and stick together
Best wishes
Post #387437 17th May 2016 6:39am
cheezels
'tis what I'm looking for.
many thanks!
Post #387470 17th May 2016 10:09am
EmiratesA380
cheezels again I hope this is helpful to you.
All My Engines are fully serviced for me - FACT Thumbs Up
NOTE: Look/Check: What Country you are in for correct mileage service in headings as below
having Engines fully serviced is paramount !!!!!!!!
Good luck cheezels
Post #387531 17th May 2016 3:52pm
cheezels
Thanks for that
Interesting there's no mention of the 3.6
Post #387626 18th May 2016 12:45am
