REAR QUARTER PANEL MOULDING - PILLARS | |
As summers here there has been a job I have wanted to do for months -
You will properly see your RUBBERS at the top are not fitting correctly - Rain water ( washing the car ) all that water will go inside which is not good.
Take off the REAR Quarter Panels - what is lurking behind them !!! - Mud - Dirt - Rust ????
I have detailed a list of instructions in case you fancy doing yours - Time taken about 2 hours.
Step 1
GET THE CORRECT TOOLS OUT:
Very very small FINE Drill Bit see pics
The Reason why you need a Very Fine Small Drill bit is that the LUGS that are holding the plastic in place are Push Home Once ..... - But I don't play that game. ( What Goes In Must Come OUT !!! )
so by drilling a very small hole in the dead center of the plug - you can screw a very sharp screw in & Pull the sucker out
and then re-use time and time again.
| Click image to enlarge |
This is how you pull the suckers OUT !
FINISHED JOB - NOW TOTALLY WATER PROOF REAR END
I used some 100% water proof plastic/rubber glue to glue the rubbers back on to the black pillar covers - I have a feeling LR ran out of glue as it was a bit hit & miss on our cars - anyway Factory Job done 100% water sealed now.
LOOK AFTER HER & SHE WILL LOOK AFTER YOU
Again - I hope this helps anyone who reads it - best wishes FFRR owners - enjoy the summer
