Home > Technical (L322) > memory seat position.
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Hi Everybody !
When I use my key fob to unlock the car my drivers seat moves to a position that has never been set in its memory! It virtually 'lies flat' ! I have to press, and hold in, the number 1 memory button to move it back to the position that it was in when I left the car. I have used my spare key to unlock the car as well and the same thing occurred. Any advice will be great, thank you.
Also, when you wish to memorise a position, you press the M button followed by the number buttons, 1,2 or 3, should a ping be heard?
Cheers 'Knowledge Is Power'
Post #386982 14th May 2016 5:57am
Mr Tee
From memory, no bong on memory set, well mine never used to.
The key may have stored settings as they are set up for user 1 user 2 per key. A battery re- set might do the trick, someone will be here shortly to clarify Thumbs Up
Post #386985 14th May 2016 6:10am
the button lights up if i remember correctly but no bong.. ... - .- -.
Post #386996 14th May 2016 7:15am
I never had a 2002 car but I'm pretty certain they bonged when you set a memory position.
If you have tried setting a memory position on both keys and it still lays it out flay then something is wrong, try the battery disconnect for half an hour and see if it clears it Discovery 4 HSE
Post #387013 14th May 2016 8:37am
As above - they key may not be paired with Memory 1 - the idea is that each driver/key has their own memory position.
Try programming the position for Memory 2 to be the same as Memory 1
Post #387015 14th May 2016 8:39am
The seats don't make any noise on programming, as Stan says the memory button lights up when in programming mode.
This is not linked to the keys, the seating position for the Lazy seats is the last set...
So it appears you have a faulty Lazy seats feature, you can turn it off with an IID or similar, or the dealer can....
From the Handbook
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #387041 14th May 2016 10:08am
Videoman1959
recliner seat !
Thank you for your comments lads, however...
Today, I thought that I would use my key to manually unlock the door and see if the seat moved into this reclined position... I turned the key, opened the door and the alarm went off! I shut the door quickly and relocked it by using the remote and then, opened it again with the remote button. The seat stayed in its original position.... I have since locked and unlocked the car using the remote button, and goes what? The seat doesn't recline/lay flat !! Smile
I know what I did isn't probably in any manual, but it appears, so far, to have worked !
Great stuff!
Cheers again... I wonder if I should become a 'consultant' on RR problems?? lol 'Knowledge Is Power'
Post #387182 15th May 2016 5:57am
After 30 posts too! Brilliant Very Happy Discovery 4 HSE
Post #387249 15th May 2016 7:17pm
Videoman1959
update about Memory Seat position
Just to let you know that the memory for the drivers seat has been perfectly fine since I used the key to manually unlock the door ! I even have the Numbered buttons working correctly with differing seat positions ... All is Good ! Thumbs Up
Thank again for your advice. 'Knowledge Is Power'
Post #389550 31st May 2016 6:01pm
We like cheap fixes...... Thumbs Up Pete
Post #389563 31st May 2016 7:04pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
So what about wrong mirror positions on memorised positions?
Mirrors move inwards a lot.
And also seat cant really find exact position. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #457653 17th Nov 2017 8:00pm
standupking36
my n/s mirror has a mind of its own at times to
Post #458005 20th Nov 2017 11:03pm
