Home > General > Range Rover Vogue 4.4 TDI Purchase
Jay1964
France
Hello to everyone,
I am currently looking to purchase a Range Rover and at this present time am very interested in a Range Rover Vogue 4.4 TDI V8, year 2011 with 39.100miles on the clock.
Can anyone please give me guidance and advise with regard to the above spec vehicle, at present I own a Land Rover Freelander 2006 and wish to upgrade with the mind that this vehicle will be used as a secondary car when towing my Ifor Williams 401 horse trailer or a caravan.
All advise with what to look for when purchasing, positive and negative will be greatly appreciated.
Thank you.
Jay
Post #386264 10th May 2016 8:33pm
welcome to the forum Jay..
you're not the first to ask this question so have a scroll down this section and have a good read..
there's also a very good buyers guide in our wiki.. ... - .- -.
Post #386268 10th May 2016 8:50pm
Baz1975
Northern Ireland 2015 Range Rover Autobiography SDV8 Firenze Red
I have a 2011 4.4 TDV8 a few weeks now, what a car!
Only problem, your right foot gets heavier every time you drive it!
Great car! Current: 2015 4.4 SDV8 Autobiography
Old: 2011 4.4 TDV8.... OMG
Old: 2003 TD6 HSE Java Black
Work: 2016 VW T6 140
Post #387165 14th May 2016 10:10pm
Diddley
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Apparently oil sits in a pipe and when you drive spirited once in a while it blows through the turbo and you get smoke!
Solution and you won't need much incouragement after driving spirited once, put your foot down more often and listen to that v8 growl. The oil won't get chance to sit around long.
I have had my 4.4 tdv8 se a fortnight now and it's a cracking car.
Post #387208 15th May 2016 12:02pm
Above issue is corrected via LR TSB and involves fitting a new a drain pipe back into the sump. Its a 9 hour tickets and involves drilling a hole in the block for the oil return. If outside 3 year warranty its get your wallet out time. Not every car has this issue but it was the earlier 4.4 cars. You may get LR to pay if you complain to LR customer services.
Post #387236 15th May 2016 4:11pm
tsb LR00513 for your info. ... - .- -.
Post #387244 15th May 2016 5:59pm
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
Bonjour Jay,
I have a 2011 tdv8 4.4 that I might be selling. Send me a PM if interested..
Cheers,
JJ
Post #387255 15th May 2016 8:00pm
