Home > Maintenance & Mods (L322) > Expedition rack , will it fit ??
Stew 46
England 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Ok chaps I've got a nice one on my disco 3, will it fit my ff ?? , do I need roof bars or rails ??
This is the one I would like to fit
Not sure why the pic does that Confused
Post #386142 9th May 2016 9:26pm
How much is it worth to sell Stew? May be worth considering selling the Disco one and buying a FF one??? Thumbs Up
Post #386149 9th May 2016 10:57pm
Stew 46
I'll have to check the prices out , I would think it's worth 475-525 ish , not sure how much a ff one is ?? Thumbs Up
Post #386150 9th May 2016 11:00pm
Around the same and upwards... That i think would be the best idea Thumbs Up
Post #386152 9th May 2016 11:09pm
Stew 46
Yes I think your right , mine has the full non slip floor in it .
Post #386153 9th May 2016 11:11pm
Ive just bought one the same for wife’s Disco Thumbs Up Gen JLR without lights so will re-powder coat it before fitting Thumbs Up
By the way, are you still looking for an A bar pal?
Post #386155 9th May 2016 11:54pm
Stew 46
Yes I'm still wanting an a bar Thumbs Up
Post #386160 10th May 2016 5:51am
sako243
Stew, one thing to point out about the FF one is that with out the hen's teeth windbreaker (like on the G4s) it howls like a banshee above about 55. Thankfully a few quid down at the local DIY / Builder's merchants for some pipe cladding and cable ties sorts that out.
The FF one is very simple to fix to the car, if the Disco one is the same then why not simply try? I suspect because of the stepped roof they won't be. Ed
Post #386161 10th May 2016 6:10am
Stew 46
I thinks it's to do with the slight curve on the ff roof Thumbs Up
Post #386163 10th May 2016 6:17am
sako243
I was referring to the step at the back of the Disco roof rather than the step in the FF roof rack. But I think unless you fancy fabricating some stuff then it's unlikely to fit.
Just a gut feel, I haven't seen the Disco one up close. Ed
Post #386167 10th May 2016 7:11am
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
[quote="sako243"]Stew, one thing to point out about the FF one is that with out the hen's teeth windbreaker (like on the G4s) it howls like a banshee above about 55. Thankfully a few quid down at the local DIY / Builder's merchants for some pipe cladding and cable ties sorts that out.
Its not that bad. THIS WRECKAGE
Post #386199 10th May 2016 12:09pm
Stew 46
Thumbs Up well with having my own building company I'm sure me or my joiner or fitter can fabricate something that looks the part and most of all works well Thumbs Up Thumbs Up
Post #386209 10th May 2016 2:09pm
