![]() | Home > Maintenance & Mods (L322) > Do My Brake Discs Need Replaced? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
^ its the pads which are the problem steve.. ... - .- -.
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 353 ![]() ![]() ![]() |
Bellini I have seen a few things ... but those disc's are past their sell by date ! Its just as easy just to change the Pads & Dic's at the same time - I just buy everything and change the whole lot in one hit and you know they are 100% spot on. good luck |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
Ah Thanks Stan!
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
I guess if you have an expensive motor it is always better to change but if you are on a budget you may think differently.By rights you only need to change if they are warped,cracked or below the recommended thickness but even looking at Haylands picture it just goes to prove what discs can take.The discs on my work van were recommended changing by the garage on service because I had 'blued them' but they are still going strong 30,000 miles later.I also put Blue point pads on the front of the FF and I cannot tell any difference except they were £23 ! |
^Rangyman, you don’t have Brembo callipers on your 04 so............ This thread does NOT apply to your model sir |
