Home > In Car Electronics (L322) > tdv8 rear tv |
STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65 |
8th May 2016 3:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
you certainly need to find an exit or back button of sorts.. ... - .- -.
8th May 2016 3:48pm |
Only just bought the car there is no remote |
8th May 2016 4:09pm |
Is this not a range rover plug ?.
8th May 2016 4:16pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I've no idea what that plug is.
8th May 2016 5:21pm |
The only part in the boot in that area I think is the sat navigation dvd ? , Do you mean the centre seat on the back seat's where something is located? . |
8th May 2016 5:35pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Yes, the centre seat.....
8th May 2016 5:53pm |
No I don't have anything like that there ?. |
8th May 2016 6:42pm |
Had a quick Google search, you could always give someone like these a ring....
8th May 2016 6:46pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
As Alistair says, the Necvox systems are aftermarket. I have Sony screens and a Necvox DVD system in the boot in the left hand side panel. I have 3 remotes, one for each screen and one for the DVD system. The DVD system has a magic eye in the cabin for receiving the DVD. If you have a Necvox screen and DVD system, you may only have one remote which does everything (screen and DVD) or separate like mine. When I first bought mine, I found the remotes in a bag in the right hand lower boot storage area, where the towbar box is when fitted. I store them in the top of the front centre arm rest. Hopefully you'll find them somewhere in the car as there are loads of places they could be. Also would expect there to be some headphones too.
9th May 2016 12:16pm |
Yeah doesn't look like I have that in my boot . Guess it's probably easier to start again because I guess they just work as a tv screen? ?..I also can't find a remote
9th May 2016 9:00pm |
If you select TV on the main screen, does whats on the main screen also appear on the rear screens (even if you don't have an active digital unit it should still show a channel number or AV code on the screen) It is possible that stilll won't show anything if the rear screen mode is looking at the wrong source input. If its like any other Necvox screen you should be able to do most things on the screen without the remote.
9th May 2016 9:54pm |
I won't allow me to do anything apart from change the colour or shade etc it's stuck on one screen and that's it .
10th May 2016 4:38am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
What about contacting the previous owner - ask them if thy have the remote in a draw somewhere?
10th May 2016 8:16am |
