Home > Maintenance & Mods (L405) > Seat Belt Bong Disable
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
Hi Folks,
Let me preface this by saying:
1. I'm new here having migrated over from Defender2 and this may have been done already.
2. This is not an original solution but the seat belt bong irritates me. Not because I don't wear one but, well you all know why.
The cure I have discovered is:
1. To sit in the car. I closed the door.
2. Ignition on, ie press start/stop without your foot on the brake.
3. Then insert the driver's seat belt in the receiver and then release it.
4. Do this eight times. There will be no sounds.
5. Then insert for the ninth time. At this point, there should be a single ping sound.
Then undo the seatbelt again and hey presto, no more nagging seat belt sounds as you move off etc.
As I say this is not my solution but one I found on another forum. I couldn't find it searching the L405 here, so I thought I would post.
My car is a 14 reg Vogue SE 4.4.
Simon
Post #385772 7th May 2016 3:34pm
this works on the L322 btw.. ... - .- -.
Post #385775 7th May 2016 3:41pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Just so you know, it disables the seatbelt warning pictograms in the dash display too.
Post #385779 7th May 2016 4:30pm
Macpaul
That's odd. I still get the red warning symbol on the display, just without the noise. Unless the pictogram is something else.
Post #385794 7th May 2016 5:14pm
teeleh
Netherlands 2019 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Handy, any info how to get it back to chime ? Land Rovers that are part of my car timeline since I bought my first RR Classic in 1999:
CURRENT
D250 Autobiography MY2023 – Charente Grey
P510e Autobiography MY2023 – Carpathian Grey
EVOGUE Cabrio MY2017 – Stornoway Grey
GONE
SERIES III MY1982
P530 LWB First Edition MY2023
P400e Autobiography MY2020
TDV6 Autobiography MY2016
TDV6 VOGUE MY2013
TDV8 VOGUE MY2006 & MY2009
TD6 VOGUE MY2004
CLASSIC RRC 3.9i VOGUE MY1992 & MY1994
Post #385953 8th May 2016 6:59pm
do the same to activate.. ... - .- -.
Post #385959 8th May 2016 7:45pm
Macpaul
Yup. I tried that too and the nine times thing switched it back on.
Post #385964 8th May 2016 8:14pm
mzplcg
Didn't work on my 2011 L322. Tried several times and got fed up with 20 repetitions.
Post #385970 8th May 2016 9:06pm
Emperor Mong
It definitely works in the L322. I did it to all of mine, including the MY11 I had.
Post #385971 8th May 2016 9:28pm
p38arover
Australia
Now tell me how to disable the bong when the key is left in the ignition with the door open! Very Happy Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #385984 9th May 2016 12:10am
Kam
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Key.... Ignition?? What is this thing you speak of?
Post #387680 18th May 2016 1:16pm
Have done this in all mine over the years and just done it in my Discovery 3 Shoot bus too. Thumbs Up Discovery 4 HSE
Post #387713 18th May 2016 6:03pm
You need to fit black wheels sir Whistle That way the ign switch bong no longer works Whistle Whistle Whistle
Alternatively, you need to Change the CCF file... Thumbs Up
Post #387769 18th May 2016 11:43pm
p38arover
Australia
I'd rather have the bong than black wheels! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #387809 19th May 2016 10:32am
abuss
Switzerland 2013 Range Rover Autobiography 5.0 SC V8 Firenze Red
works perfect! no more bong..
Post #387845 19th May 2016 1:25pm
