Home > Technical (L322) > Annoying ticking sound
Andy
I've noticed when I get into the car I can hear a rapid electronic ticking sound coming from the dash every so often. It sounds like one of those tills that produces paper receipts. Does it every 10 mins or so. I only noticed it today when I got in and sat waiting for my wife.
It's also got a constant hum without the key being in the ignition. Sounds similar to a fuel pump whine but lower. That keeps starting and stopping as well
What is it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #3833 14th Mar 2009 6:50pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
the whinning is probly the air sus pump in the boot but it normally only comes on with ignition , have you got a EAS leak ? onto no6 Range Rover
Everyone needs a hobby
Post #3854 15th Mar 2009 8:38pm
These cars make ALL sorts of noises when the engine is switched off. Just take into consideration the myriad of electronic systems all being primed at the ready for when you want to drive off.
Get worried if you see oil, water, or metal bits bits all over the driveway! Discovery 4 HSE
Post #3857 15th Mar 2009 10:20pm
