Home > In Car Electronics (L322) > Stereo head unit
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Stereo head unit
Hi all,
After buying my L322 it has an aftermarket head unit and I want it back to standard so I can use the CD changer in the glovebox.
Have the 11 speaker system, I believe it's the CD53 unit that was fitted but that's just the extra cd drive?
What's the unit below it called with the screen?
Cheers Smile
Post #385663 7th May 2016 6:28am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Depending on the head unit installed, the area behind the unit in the dash will most likely have been trimmed to fit the new unit. Is it a double din? Might make re fitting what was once there pretty hard. I'm sure I have the single cd dash unit in the garage if you need one.
Post #385669 7th May 2016 7:44am
read 'how to fit an android unit' by haylands (pete) and do the reverse to get it back to standard.. ... - .- -.
Post #385674 7th May 2016 7:58am
Stacker
Mr Tee - Pm sent
Stan - just had a look, as far as I know mine never had a touch screen as the car in the tutorial did, thanks though
Post #385686 7th May 2016 8:38am
not a touchscreen mentioned here,
http://www.fullfatrr.com/forum/topic29219.html ... - .- -.
Post #385700 7th May 2016 9:29am
All the original parts on these early cars are now very temperamental and cost a fortune when they fail... remove what bit's you have, stick the android unit in, it will play any disc from cd to dvd and will also do ipod and a 32gb memory card, you can usually sell the bit's in yours to offset the cost, I even made a few quid in the swap... Thumbs Up Thumbs Up Pete
Post #385718 7th May 2016 10:14am
I agree - it was most likely swapped for a good reason Thumbs Up
Post #385749 7th May 2016 1:13pm
