Home > Maintenance & Mods (L322) > 3.6 Oil Drain Using Vacuum
Page 1 of 3 123>
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
On previous cars I've had, I've used a vacuum pump to suck the oil out of the sump, for oil changes.
Less mess and stress.
I can't really find any info'on here saying not to do this with the 3.6 engine, and my local Dealership says that's how they do it.
Any reasons for not using a vacuum pump?
I know there are 2 sump plugs, but I'm wondering if the vacuum method is approved.
Post #384960 2nd May 2016 10:56pm
Most JLR agents use the Vacuum method sir... In fact, if you have a 4.4 then thats the only approved way to change the engine oil...
Because of that, most use the same method on the 3.6’s sir...
Post #384962 2nd May 2016 11:08pm
cheezels
Ok, thanks for that.
I guess I'm a bit worried about what I've read about possible links between not draining through both sump plugs and turbo failure.
So, the vacuum method gets all the oil out, or is there some left warranting the use of the sump plugs?
Post #384964 2nd May 2016 11:16pm
I did my last 3.6 using the vacuum method, then removed both plugs and got a very small amount out! Same with the 4.4 TDV8 i own now and again got a dribble out of both!
Neither car had any lumps or sludge from either of the plugs/bungs BUT! Im sure if the oil is regularly changed they wouldn’t anyways! Thumbs Up
Post #384969 2nd May 2016 11:37pm
There will always be some left, the pipe won't sit on the bottom and suck the lot out, but I bet there is more oil stuck in nooks and crannies in the rest of the engine than left in the sump... really can't see any link with that small amount of old oil and turbo failure... Pete
Post #384970 2nd May 2016 11:38pm
cheezels
OK, thanks again, all sounds logical.
Vacuum method it is.
Post #384974 2nd May 2016 11:41pm
Post #384975 2nd May 2016 11:43pm
wealy
Does the sdV8 have two sump plugs?
Post #384994 3rd May 2016 8:04am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
The 4.4tdv8 sump plugs x 2 are (apparently) fragile and not designed to be removed often. Don't know about the SDV8. The pumped method came in due to health and safety and hazardous materials handling regulations so one would assume the method is capable of doing the job properly. I note Craig only has a dribble out of the sump plug so it seems like the pump method does the trick. Thumbs Up
(and its so much cleaner and easier) 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #385057 3rd May 2016 12:55pm
wealy
Fragile?????
Which brain box designed a fragile sump plug that shouldn't be removed often??
Big Cry
Post #385067 3rd May 2016 1:39pm
Does the 4.4 actually have sump plugs? I thought it just had a push on connector for the scavenger pipe? There is nothing that can't be fixed with a hammer😜😜
Post #385096 3rd May 2016 5:10pm
It does have a sump bang but it's under the subframe meaning you could not drain the sump as there would be oil jettisoned everywhere!!!
Post #385098 3rd May 2016 5:13pm
wealy wrote:
Fragile?????
Big Cry
Welcome to the new age of servicing sir! Mercedes have had the same system for years! Thumbs Up
Post #385099 3rd May 2016 5:15pm
top forethought and planning there...... is it by any chance blocked by the subframe on the 405 too? Didn't think there was a sump drain option :thumbs: There is nothing that can't be fixed with a hammer😜😜
Post #385100 3rd May 2016 5:24pm
wealy
The 405 does not have a dipstick? So where do you put the vacuum pipe to suck it out?
Post #385366 5th May 2016 1:55pm
Page 1 of 3 123>
