![]() | Home > Technical (L322) > fuel level sender |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
unfortunately you can't just replace one, the thing comes as a pretty large kit with the lift pump too. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
There was a post about eradic gauge readings being possibly caused by corrosion at the sender unit connectors on the outside of the tank.
under the back seats. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
The TSB was for the internal electrical plugs onto both tank sender units sir...
krisleeds Member Since: 19 Oct 2014 Location: leeds west yorkshire Posts: 60 ![]() ![]() ![]() |
From what i have seen on the manual is that the connections are on the pump side under the inspection panal. Is this correct |
Just an update, i set about testing my senders.
