Home > Technical (L322) > EGR warning - post mortem findings
Page 1 of 3 123>
sako243
The engineer in me (and perhaps the Scot) upon taking off the EGRs on my FF decided to pull apart the assembly. The engineer hat to see how it was built and what the problem might be. The Scot to pilfer parts as the motor looked quite a nice size!
Anyway the saga started when I intermittently (twice in about 4 months) saw the P045-6C so decided to replace the valve assemblies.
This is what I found:
You may notice the small piece of metal, that formed part of the claw which moves the valve stem. When I opened it it was inside a guide rail of the valve so not the best place.
So pay attention to those error codes! Ed
Post #383546 24th Apr 2016 6:33pm
sako243
And exactly the same thing had happened to the other one. Except this one looks like its been blowing exhaust into the motor housing.
 Ed
Post #383548 24th Apr 2016 6:41pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Quite interesting.
Did the valves fail in the open or closed position?
Any signs of cooling water leakage. I read a theory that the egr may leak coolant, possibly leading to turbo failure.
I'm thinking of fitting emulators so interested also to find out if there's a possibility of the valve leaking exhaust gas when it's in the closed position eg sealing face wear
Post #384217 28th Apr 2016 8:19am
sako243
They hadn't actually failed - the ECU was detecting that sometimes it wasn't getting the full range of movement.
With regards to emulators I think that the ECU also has sensors (maybe just temperature? - it's in the workshop manual I think) to monitor the behaviour. So if those don't fall within parameters it detects it. Interestingly there are only two connections to the motor. So haven't looked into too much depth if it gets its feedback from that connection or somewhere else.
Will have another look when I go to put them back on the car. Ed
Post #384226 28th Apr 2016 8:56am
cheezels
Thanks for that
Can't quite tell from the photos if it's a butterfly valve or poppet valve
Is there a chance the valve could leak when closed?
Cheers
Post #384245 28th Apr 2016 9:34am
sako243
It's a valve like in the cylinder heads. Basically the motor turns a couple of cogs, that then rotates a the valve stem which has a couple of lugs which run in guides in the casing. As it rotates the stem moves down the case and opens the valve. Ed
Post #384258 28th Apr 2016 11:51am
cheezels
Ok cool. Thanks again
Post #384261 28th Apr 2016 12:07pm
gbmud
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
The Tdci engines in Defenders apparently detect AGR faults - like removal or blocking up - by measuring an expected decrease in the MAF reading when the EGR is open. If the MAF does not drop with the EGR open (as exhaust goes in instead of fresh air) then the EGR must have failed and it shows the MIL lamp. Maybe RRs use the same idea?
Chris
Post #384402 29th Apr 2016 7:40am
sako243
That rings a bell Chris. Ed
Post #384405 29th Apr 2016 8:15am
Can't you get them deleted with a remap..?? Pete
Post #384414 29th Apr 2016 9:26am
sako243
Probably - but then they are there for a reason Whistle
I haven't heard of any of the reputable people mapping them out yet but I haven't been looking to be honest.
If I ever get some time / a garage of my own then I might be tempted to try it myself (perhaps with a spare engine - anyone willing to donate one?). I think part of the problem with the facelifted stuff is everything talks to everything else even more than it used to. In the various forays I've had into the workshop manual it details what sensors are on there and how they work so not too difficult to reverse engineer and build an Engine Control Unit, i.e. something with a loud pedal and an engine - none of this gubbins in the middle Rolling Eyes Ed
Post #384446 29th Apr 2016 1:16pm
miggit
I would take a look at the slightly smaller version of that engine (V6) the EGR delete re-map is a must do, just because you've got 2 extra cylinders doesn't mean that the V8 will not suffer similar problems to the V6, infact I think that you'll find there are a lot of common faults...... turbo hoses, turbo's and EGR's for a kick off Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #384447 29th Apr 2016 1:25pm
sako243
Very true but they do have completely different layouts which does contribute. The V angle is different to my understanding and because of this the turbos on the TDV8 are lower down because they can't fit them on top. Ed
Post #384647 30th Apr 2016 9:36pm
Mikey
The TDV6 and the TDV8 are not related, in any way, shape or form Thumbs Up
Post #384649 30th Apr 2016 9:39pm
Was always under the impression that they were both developed as part of the Jv between ford and PsA. On he face of it they are completely different as they have different v angles 60deg for the v6 and 90 for the v8.
The bore and stroke are however exactly the same as is the compression ratio. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #384653 30th Apr 2016 10:11pm
Page 1 of 3 123>
