Home > Off Topic > Boiler(no bunny!) advice/recommendation |
Over the last few years the Worcestor greenstar 28i that was fitted here has become more and more unreliable despite the annual servicing and with the imminent install of a thermostatic shower to remove he old electric one in worried failure will become more often leaving us not even able to have a shower in the morning.
24th Apr 2016 1:14pm |
How much is an hour of labour these days for one of those? Are there such things as dedicated boiler engineers to a specific manufacturer these days? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
24th Apr 2016 3:35pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Yes, Worcester Bosch have their own engineers. I used them when we had a new WB boiler fitted by British Gas and after one day the boiler failed due to an installation fault. Another British Gas engineer then promptly condemned the installation.
24th Apr 2016 4:16pm |
Id have to try and phone them tomorrow and no doubt be stuck with everyone else who has had failures over the weekend as well so id still be looking at Wednesday for an engineer to attend really and then God knows how long for parts.
24th Apr 2016 5:17pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Im sure WB do a fixed price repair. |
24th Apr 2016 5:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
How many showers are you running off the combi?
24th Apr 2016 6:57pm |
That's regulations now anyway. The installer has to powerflush the whole system when fitting a new boiler. And yes, a sediment filter on the CH circuit is a good thing, as is a scale filter on the incoming cold feed. As for recommendations, I replaced a 10 year old WB with a new Vaillant last year. I did look at another WB as it gave such good service but the thing for me was a 7 year warranty on the Vaillant. And what a difference once it was done as well. Hotter showers, more even central heating and lower gas bills. Perfect. |
24th Apr 2016 7:20pm |
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 |
Sadly, everyone seems to be advised to fit combis these days, the simple reason being that they are quicker to install. But instant hot water comes with a few hidden issues - the heat exchanger is half the size of a cornflakes packet, and to raise the incoming mains temperature to 30 Celsius in the time it takes for the water to flow thru' the exchanger, the poor little thing is cherry red, and the thermal stresses involved are extreme. They ain't cast iron or indeed have any steel in them. Generally pressure-formed aluminium Worth checking if a pressure reducing valve has been fitted upstream of the boiler, as they don't like more than 3 bar on the inlet, obviously this adds to the heat exchanger's woes.
24th Apr 2016 10:46pm |
The reason a gas condensing boiler is now invariably fitted in domestic dwellings is that it is now a requirement under the Building Regulations in England, Wales and Scotland.
25th Apr 2016 7:41am |
I fully agree with fretless a system boiler and Un vented tank is the way to go for best hot water performance, I am about to fit 2 of these systems with baxi boilers to the new 4 beds I'm doing at the moment, it really does depend on how much space you have though, if there is plenty in the boiler cupboard then fitting a tank may be an option, however if you have to have the tank remote from the boiler then a flow and return to the tank would have to be plumbed in as well as a cold to and hot from the tank and pressure relief Pipework so this may not be a practical solution in most cases.
25th Apr 2016 2:37pm |
Unfortunately space and long term cost of keeping any sized tank hot for on demand water would prove more than I could stomach and if have to find the room and time to do all that extra plumbing with my dad
26th Apr 2016 8:35pm |
Oh and only one shower in the house and three hot taps with only one tap and shower ever likely to be used at the same time FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Apr 2016 8:36pm |
26th Apr 2016 9:32pm |
Yup, 28kw does 11litres/min and 40kw does 16litres/min so I get almost a 50% improvement in hot flow for about 15% more ££ which for me is a no brainer if it comes to it 😄 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Apr 2016 10:18pm |
