Home > Maintenance & Mods (L322) > Vent control illumination and other niggles
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Day 2 of Range Rover SC (06) ownership and boy what a car....
I've came from a BMW 740D MSport so things are a bit different especially the view.. 😜
A couple of niggles as expected with every 2nd hand car...
Vent illumination is only working on one of the vents. Is this a common issue ? I'm assuming it's an easy but laborious fix ?
The drivers side step is absolutely rotten 😫
Rear near side window is non responsive to rear switch and drivers switch. I can hear a relay or control module clicking somewhere on the left of the car. Plan is to remove the door card and have a butchers.
Had a very brief flicker of the airbag warning light on the dash. It's been on 4 or 5 times... For anywhere up to a minute.
I've looked under the passenger seat having had similar problems on a previous 7 series and the cables are all hanging loose. Will give it a tidy up and see if that resolves it.
Chuffed to bits to have stumbled onto this forum as I was an avid forum user for my previous cars ☺️
Post #383298 23rd Apr 2016 7:13am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I've got the same issue with the rear drivers door window not working (oddly enough in summer is sometimes works), the click comes from the body control unit under the front passenger seat. I think it could be the motor module for the door that needs replacing (glass out job) but have heard another option is a faulty BCU, so far I have not had the time to investigate further. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #383359 23rd Apr 2016 1:21pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I have the same car and the centre vents should both illuminate. The side ones are mute.
One of my middle ones does not work. I think it's the passenger side.
I spoke with the stealer to get a bulb and they don't do them separately. Complete centre unit at circa £300. No thanks. I'll live with the darkness!!
I've not tried to source just the bulb yet. Powerful UK site has an instruction video to remove the centre vents to get to the bulb. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #383376 23rd Apr 2016 4:22pm
blackstoun
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have the same car and same year (and same colour)
My airbag warning light did flicker on and off for a while , then stayed on
turned out to need a new air bag sensor
got it fixed at a local indy who seems to be quite good, because i didn't fancy disconnecting airbags etc, to do it myself
Depends how confident you are I suppose
[www.prestigejaguar.com] They are in Paisley, near St Mirrens ground
Post #383408 23rd Apr 2016 8:38pm
StewD
Excellent thanks for the updates 👍
I'm nearby so will pop into Paisley next chance I get...
Post #383437 24th Apr 2016 1:21am
StewD
So... Stripped off the door card hoping for a nice simple cheap fix..
Figured someone else had been in before me as the screws had signs of being undone previously....
Only to find this !!
Some skilled mechanic has stuffed a big dirty self tapper in the mechanism to jam the window closed.
So looks like I need a new mechanism 🙄
Post #383500 24th Apr 2016 1:21pm
StewD
Loads of them on eBay, nice and cheap too...
So will still be a nice cheap fix 👍
Any tips ?
Post #383502 24th Apr 2016 1:28pm
StewD
Dash centre vents removed and bulb extracted...
It's a BMW part, number: 61138352935
Only one seller on eBay at £16 each ☹️
Will research an alternative and report back 👍
Post #383527 24th Apr 2016 2:54pm
