Home > Off Topic - Other Cars > 3.9 RR Classic efi auto wont start |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
I have also had the coil short out, mine has a plastic bottle bottom over it.
21st Apr 2016 7:11pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
Thanks for the latest input Gents - i'll keep digging...
21st Apr 2016 8:39pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Wouldn't have thought it was the ign barrel, as its cranking ok.
21st Apr 2016 9:48pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
That is a classic cold start problem, most Lucas systems that are pointless run the coil between 6 and 9 volts, but give it a little kick with 12 volts when starting..... It sounds like this has gone a bit astray.... but easy to fix..... you need to run a wire from either the starter motor energiser wire ( that will be the thin one on the starter ) or from the starter motor main feed on the starter side.... follow the lead from the battery to the starter, it will go to a large terminal, there will be another one with a lead going in to the starter, this is the one that you want..... with the lead attached to the starter end attach the other end to the coil on the + side, if your not sure which is which, it's the wire that stays live when it's removed from the coil.
21st Apr 2016 10:32pm |
Just a thought, is the engine block earth lead OK? Regards
22nd Apr 2016 5:35am |
It reminds me of my first car a Triumph Herald. When it rained the ignition would stop working. The primary wire insulation had gotten sooo porous that it shorted to earth due to the water. Replaced the wire and all was fine. Also installed a new wire from ignition to starter motor relay due to the same problem (actually from a starter switch as the ignition switch gave me other headaches at the time).
22nd Apr 2016 6:17am |
Thanks again all.
22nd Apr 2016 12:22pm |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 |
Hope you get sorted soon . Have you got an engine immobiliser fitted? Had sudden engine cut out on mine a few years back...... |
22nd Apr 2016 12:54pm |
Thing is I dont actually know if an immobiliser is fitted.
22nd Apr 2016 4:05pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
The point about the immobiliser is a good one. I had forgotten that my 3.5 Classic's (aftermarket) alarm/immobiliser went wrong and I had the immobiliser removed. Well worth checking. Only Range Rovers since 1988 |
22nd Apr 2016 4:43pm |
How does one know if an immobilser is fitted? Where is the magic black box? 405 AB exec seats Baltic and Cirrus
22nd Apr 2016 4:51pm |
Sorry, I don't recall where mine was. A local indy dealt with it without me seeing what he was doing. This would have been about 1990 and there were lots of different aftermarket alarm/immobiliser systems, not necessarily all working in the same way. I think mine was made by Cobra. There was a remote control fob that could be attached to the RR keyring. If you don't have anything like that then perhaps there isn't one, Only Range Rovers since 1988 |
22nd Apr 2016 5:34pm |
Ignition wafers are part of the electrical side of the ignition lock..... it is made up of several components, the key / barrel, then the steering lock, and then the rotary electrical switch, which is turned by the key...... this is made up with several wafers that turn, and they have a conducting track on them that makes the different circuits operate depending how far the key is turned.... They are housed in a round plastic affair that is located the opposite end of the key side of the ignition lock I don't think that you can buy just the wafers / switch, it is normally part of the ignition lock assembly which is really annoying as you can normally buy the key side on its' own
22nd Apr 2016 9:56pm |
This shows how a very basic one works.... and being a Range Rover .....
22nd Apr 2016 10:05pm |
