![]() | Home > Technical (L322) > What would cause oil to come out of diff breather? |
Mikeinatruck Member Since: 14 Apr 2016 Location: Dumfries Posts: 50 ![]() ![]() ![]() |
When everything is spinning in the diff its quite chaotic and the oil will be thrown to hell and back so it could just be it is blowing out the line, that said its not the norm... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Sounds like the levels too high, and when it gets hot the oil expands to drips out the breather.... If you fill your own diffs then you have to make sure that the car is perfectly level... if it isn't then this can effect the level in the diff and cause the problems your describing.... |
Deanicuss Member Since: 05 Aug 2014 Location: Cornwall Posts: 77 ![]() ![]() |
My indie did the oil level on the ramps but it was doing it before this as I originally thought the diff seal was leaking. I'll get them to check the levels again. Thanks guys. |
Has the breather got a hooked top.... only if it hasn't then that could be the cause... also if it has been shortened in it's life could be another thing... Yesterday I couldn't spell Engineer... Today I are one!
It's like this |
The bloody photo is the wrong way round again, must be my phone. |
You haven't been in deep water by any chance? only it might have filled the diff up and the oil is floating on the top... just a thought.... Yesterday I couldn't spell Engineer... Today I are one!
No its brand new oil, It was done 3 weeks ago but was still coming out prior to the oil change. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Sounds like it's slightly overfilled.
Diff's are filed with a measured amount of oil (available in the wiki) not up to the top till it runs out of the fill hole .Drain and refill with the correct amount and then see if it still comes out of the breather , I'd put money on it not .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
And the confusion is that on the early BMW FF's the fill plug IS the level, so you fill it until it comes out...
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
There is a landrover technical bulletin regarding this as I had the same on my 04 4.4. I'm away so can't post it as there are several causes but the way I solved mine was to drain and refill with the correct amount of oil which is different to rave.
