Home > Technical (L322) > Really Stupid Question but............
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Really stupid question but what the cylinder layout on the 4.2sc?
Is it looking from the front left front number 1 and right front number 5?
I have an issue with number 8 and need to locate it quick.
Thanks
Post #382071 14th Apr 2016 11:09am
from WM, any help?
Post #382090 14th Apr 2016 12:19pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Cylinder 1 is usually nearest the radiator.
So it would follow that cylinder 8 is the one nearest the bulkhead.
Does not matter if cylinder 1 starts on bank 1 or bank 2, the same rule applies.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #382161 14th Apr 2016 7:02pm
lighthouse
Thanks guys appears to be correct from what Stan has found. 1 is front left and 5 front right.
Managed to clean my gas injector on number 8 and all good now so thanks guys you have helped cure my reduced engine performance issue.
Post #382193 14th Apr 2016 9:38pm
