![]() | Home > Technical (L322) > Small problems |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
Welcome....
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I read 'the jeep' and then checked the flag..........it wasn't stars and stripes. |
roscomc Member Since: 11 Apr 2016 Location: glasgow Posts: 6 ![]() ![]() ![]() |
Sorry lads , I'll edit the post lol. When it does work the you can hear it when u press the button. But it hardly every does, the latches seem fine as there well greased up. Seems to be the button |
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
'Sounds like the actuator is in need of replacement. Had same symptoms with my D3. £45 and 20mins work and all was well again. Not sure how much actuator will cost for RR but someone may have one lurking in a box somewhere or you could try Dan at Duckworths. |
Welcome |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
More likely to be a dodgy switch, they are not exactly in the best place to ensure that water doesn't sit on/in them.... and we know how good the L/R seals are |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Another thing it may be worth trying is to check the lock mechanisms are clean and lubed up, you can try WD40 initially but if it works use something more permanent. Another way to check if it's a mechanical 'friction' issue is to push on the lower tailgate (towards the front of the car) a little and then press the button. Mine was doing similar and some white lithium grease sorted it for the remaining 3 years I had the car.
FYI, I'm sure that I've seen a thread on here about replacing the camera with a cheapy one from fleabay..... hopefully someone can shed some light on this |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi
