Home > Technical (L322) > Wet Patch
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Wet Patch
Well, I thought I'd spend time getting to know my engine. TDV8 3.6
Very different from the V8 Thor!!!
So all dusty and dry as I shone the torch but then, in true expected LR fashion I spotted a small wet patch.
Tried to take a pic but couldn't get access.
As you look at the car from the front on the left hand side of the engine about half way down the is a metal pipe joined in the middle by a hose connected with two jubilee clips. This hose is very close to the steering rack column. It appears to be wet, not a great deal but wet oily.
Does anyone know what this is? If I was to guess, maybe auto transmission pipe to the cooler?
Cheers in advance
Jerry
Post #381579 10th Apr 2016 8:37am
rar110
Gday Jerry
It sounds like you're looking above the steering rack which would be the driver side turbo area. I seem to recall you replacing both turbos. ______________________________
Post #381824 12th Apr 2016 12:09am
rar110
Jerry, think this is what your looking at.
I would try tightening the clamps, degrease it and see if oil returns. ______________________________
Post #381840 12th Apr 2016 8:02am
Road Stone
Hi Pete,
Yes thats the one and yes both turbos replaced. Is it from the turbo and if so, what does it do?
Many thanks for the pic.
Cheers, Jerry
Post #381848 12th Apr 2016 8:44am
rar110
Gday Jerry
It's the turbo output pipe going forward to the intercooler. Here's a pic from the WSM.
Post #381866 12th Apr 2016 12:33pm
Road Stone
G'day Pete,
Well you were spot on. When I put my hand down with rag to clean the crud, the top clip spun around, completely loose.
Cleaned up and tightened.
That picture helps too, Many thanks and appreciated.
Cheers, Jerry
Post #381937 13th Apr 2016 4:56am
rar110
No worries. An easy fix. It might be worth checking the other side. ______________________________
Post #381943 13th Apr 2016 7:40am
