![]() | Home > Technical (L322) > Stripped thread in Brembo caliper |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 ![]() ![]() |
Hi All - started to get some vibration (not good ones!) from front of car under braking - feeling like warped disks etc. I remembered when I last did brakes and disks that I was unable do get the top caliper bolt tight...
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
Yeah, just imagine driving down the road at 20mph past a school with a front calliper bolt in a helicoil, it went in OK and tightened up, but, just as you had to jump on the brakes as that 3 year old ran into the road, the helicoil gave way, you didn't lose all the brakes but that caliper moved and jammed so you lost breaking on that wheel, the car swung to one side and the side of your front wing hit the three year old's head.... 2 1/2 tons of FF at 5mph is still a lot of force.... If it hadn't jammed you would have missed the child by inches... now they have impounded your FF and found the repair, your insurance have decided your not covered..... etc etc....
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
275 Nm?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
go for timesert
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I would plump for Timesert over a Helicoil although more expensive they are more substantial.
Thanks so far - looked at the time serts - they do look more robust...
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
All measured - bolt is M12x1.5 next challenge is finding a time sert supplier. appears Wurth are UK distributor but only sell to trade. Does anybody know a stockist?
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
have you thought, about contacting a brake caliper refurbisher, and letting them do the insert, it would at least have a sort of guaruntee. and they will have best equipment to do it. normally they would be doing the hydraulics, but probably have taps and sundries, to sort the rusty threads etc. |
As long as you feel you are competent to do it this pops up on Google: http://timesertkithire.co.uk/12x15tskit.htm Give the Hire cost or the cost of buying a kit taking it to a machine shop might cost the same and give a better result. |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Am sure there are engineers shops or hydraulic specialists who do this sort of work in their sleep for a fraction of the £500 for a new one ! |
Just to close this one out - when I inspected the calliper after removing it I noticed that the seals had started to degrade - slight bobbles in them so decided that I would look at a refurb so also ended up removing the other side as well. Found a refurb place and sent them off on Saturday afternoon. Just went for a mechanical refurb rather that repaint - I chose them as they specifically mentioned doing time sert repairs. Box arrived yesterday morning, repair done, new seals caps etc..
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Don't ever get on a plane if you don't trust helicoils as they are full of them as they are stronger than threading directly into aluminium |
Timbo Member Since: 11 Jun 2015 Location: Gods Own County Posts: 11 ![]() ![]() ![]() |
I know this is closed out but I'm confused by that torque setting - I did mine to 110nm or 81lb ft - I have no idea how I'd get 275nm on it! Can anybody confirm the correct number? |
