![]() | Home > My Range Rover > New owner-to-be, Hertfordshire |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Hi all,
2003 4.4 Vogue Black (is that Java Black?) LPG with a BRC system, seems to work well Factory entertainment with analogue TV and DSP Parchment or Ivory piped in black Heated steering wheel Parrot BT kit, seems disconnected though Now, thanks to this great site which I've been using to help me learn, I'm pretty sure it needs this lot - I've put my budget prices for anyone to comment on, and for me to look back on when I'm proved wrong!
LPG service - no record of it ever being done sadly. Local BRC place quoted �150 for full service with filters Exhaust blow, somewhere in the middle - split cat perhaps? Budget �50 and hope Wiper motor - it's a bit floppy at the top of its travel and there's no water flow, so budget to replace it �150 Compressor - it was slow to come to off road height, and to recover from access mode, and the compressor is a bit noisy. Same as the Jag compressor, so I can rebuild or replace. I didn't check, but I expect its been relocated away from the LPG tank which may explain some of the noise. Budget �35 for Andy's kit Rear heated seats - no lights come on at all. Of course I'm hoping its a fuse... Some cosmetics I'd like to improve:
Driver's seat bolster a bit worn. Furniture clinic kit in the summer perhaps, I'll see how it cleans up. Left dash walnut trim has had a phone mount. This will annoy me unless I can re-use it. �50 from ebay LCD is missing pixels. This kit looks decent and I'm ok with electronics: http://www.diyspareparts.net/rover.html �40 While the Foundry finish parts of the dash are good, the rear panel for the heated seat switches and the front fixed cup holder are going bad. I'll probably paint these for now Driver's side window switch panel has the rubber finish going. I may attempt to refinish or buy wood overlays. Same with the steering wheel spokes. It also REALLY needs a clean, and the corners of the back bumper have taken some wear, so I may paint this at some point. And I'd like a reversing camera (my wife can't turn her head very well) and DTV (because, well, it's there). I will update with pics when I get it! And a big THANK YOU to everyone who contributed to the wiki and various threads to give me the confidence to buy this. The Jag was complex, this is more so! I'm no stranger to fixing cars though, having had a Porsche 928, and now also have a Series III awaiting work, and a 57 Plymouth in the final stages of restoration. Cheers Ian |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Welcome to the forum
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
Sounds cool. V8 ace!
Thanks all. First task will be some major cleaning!
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Welcome Bud, Land Rover Indys.... there are 3 in your area |
Thanks for the advice! Aylmer is very convenient as I drive past every day on the school run, but I'll call the others too.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i have an lpg similar year car. i have been quoted about '�100 for an LPG service', maybe thats filters on top, and that will be with vat, say �150. and good for 2 years i was told.
Thanks for the tips! It's had two water pumps in the past, and there are no signs of leaks at the moment that I could see. I can see myself getting an IID tool just to set the access height as low as possible for my wife. LPG is a "nice to have", but having had a few large V8 vehicles I don't worry about MPG too much. My wife's diesel B-class Merc does 50+ MPG and that's used most often.
with the compressor issue, normally if the pump is running, and you open a door, it stops..... maybe, if you think its real low, and it starts pumping as you get it to start it, count to 60, and, perhaps try opening a door, and turn off ignition... maybe you will then reset the timer, and you can have another 'free minute' on the pump..
The pump didn't time out, it just took longer than I expected to reach full height.
The rear wiper/washer gets blocked up in the shaft and the non-return valve which is a couple of inches before the wiper motor... if you pop the hose before the valve, PUT A BUCKET ON THE REAR SHELF, you can get a helper to operate the wash/wipe while you direct the flow in to the bucket..... BE WARNED IT DOES SEVERAL PULSES... so there is potential to soak the car while the wiper is moving ![]() ![]() ![]() The seal on the wiper shaft can wear and cause it to leak... this will leave a rusty puddle on the inside on the trim panel that covers the motor. Info on repairs here http://www.fullfatrr.com/forum/topic9792.h...iper+motor Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
