![]() | Home > In Car Electronics (L322) > DAB very poor reception |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
If I'm stationary on the drive then DAB is OK, if I am moving then DAB is pretty much a waste of time, I guess its signal related but I'm not sure what to check, which is the DAB aerial. Anyone else got this problem - I suppose, more usefully, has anyone fixed it? Geoff |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Hi
I just had a quick Google and it appears DAB uses Band III in the UK not Band L the default for the settings on my DAB is Band III and Band L I just changed it to be Band III only and it seems much improved.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1055 ![]() ![]() ![]() |
I only ever have the radio on DAB channels. No problems at all until you wander far from populations, so basically it works pretty much everywhere except the Highlands in my experience. You do get interference when you go past police stations though..... |
