![]() | Home > Technical (L322) > Xenon headlight components |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Hi All
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
This is what I had. Behind the headlight there is a ballast. Inside the light unit itself is an ignitor. The ballast is easy to change, the igniter is a bit more fiddly as you have to take the lense of the light then undo the internal cluster to get at the ignitor (which is basically the cable that connects to the bulb). The ballast ups the power, then the igniter lights the bulb.
Ah got it now Reformed! plus I since found your old post under igniter - sound just what I need Thanks again, will post details of supplier / pn's in due course.. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
An old thread but is the Igniter the black square unit with the thick wire coming out (plus a connector with 3 wires) or is it the unit which is attached to the side of the xenon light holder (see pics 1 and 2)
MattChaloner Member Since: 12 Oct 2014 Location: Corsham, Wiltshire Posts: 52 ![]() ![]() ![]() |
Hi Paul, the ignitor is the one in the first picture. to get it out you pop off all the metal clips around the headlight lens glass, remove glass lens, lift out the silver surround and then pop out the silver lenses. You need to go careful because the poppers that hold them in get brittle and can snap off. If you get stuck or would like a hand I'm more than happy to pop up and help you out as I've done this job in the past week - I'm down the road in Corsham. I've got an ignitor here you could try but I think it's intermittent. I bought 2 used ones and 1 new one and swapped around a load of different combinations so I can't remember what I'm left with, but you're welcome to try it. |
Matt,
Turns out it was a loose connection on the back of the headlamp unit |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Tagging on to this thread. As I understand it, the bi-xenon lights are the same on main and dipped beam and there is a shutter which moves when changing between. Main beam also brings on the halogen bulbs.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Should be:
I have had to change the unit but was wondering if I could rescue the old one.
Does sound like it would be related to a stuck shutter or something - either that or a wiring issue. Visiting from DISCO3.CO.UK
I'll have to have good look at it. Ta. John
