So today, I had a spare couple of hours. I've been collecting the parts to refurb my air con.
After finding the pulley belt adjuster had seized and my air con making a funny noise when switched on, it was time to have a go at fixing it.
couldn't move the adjuster, so I cut the belt to relieve the pressure. I've taken the tensioner off the rear, and the pulley bar is stuck solid in the ali casting, I suspect the ali has reacted with the steel. I can see the pulley / casting carrier can be removed, but the aircon compressor has to be removed or at least pulled to one side. I have also removed the pulley off the tensioner bar, and tbh I don't think that's my problem, but needed renewing anyway. You can't remove the pulley bar without removing the rad shroud, as there's not enough room to pull it out square.
I have also turned the compressor by hand, the clutch bit, and it feels a little lumpy, should it be smooth ?. If so looks like getting the aircon degassed as I have depressed one of the valves in the engine bay drivers side, and got a real good pish, so it's not losing pressure.
any thoughts or suggestions would be most welcome.
Thanks. Greg.
