Home > Maintenance & Mods (L322) > Oil Shelf Life
Classic888
Oil Shelf Life
Hi all. I am about to change transfer box and differential oils on my 2007MY RR S/C. one of the bottles of oil for the rear differential has what looks like a date stamp of 2010 on it!! It is Castrol BOT 720 in a plastic un-opened bottle. Is it OK to use?
Many thanks for any response.
Post #380193 31st Mar 2016 5:21pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Yes its ok, Unopened oil does not have a shelf life.
Post #380195 31st Mar 2016 5:32pm
wealy
It's been in the ground for 52 billion years!
How long do you want it to last?
Rolling with laughter
Post #380257 31st Mar 2016 10:05pm
Does it start to do off once it's opened ?
Post #380258 31st Mar 2016 10:07pm
brian1951
No but a opened container could attract debris
Post #380260 31st Mar 2016 10:11pm
Post #380261 31st Mar 2016 10:13pm
johnboyairey
if you ask an oil seller he will say 5 years till best before etc, as the oil companies state.... ask a mechanic, and he will say loads longer.
the above 52 million years, (or billion) if you think the universe is indeed that old. (more like 4 billion) try and start a car with two year old petrol, and you will find it hardly even burns, even if tipped the floor! and it stinks when it does... so I would use the 5 yr old stuff, in the transfer box... as its not exactly demanding its extreme limitations, like say, Lewis Hamiltons' Merc, at 16,000 rpm, at 35 degrees ambient air temp.
Post #380275 31st Mar 2016 11:06pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
i asked this question in relation to bike engine oil as I'd been given a large quantity of unopened fully synth engine oil that had a date on it aging it as ten years old. An oil retailer told me up to ten years is fine if its been stored at ambient room type temps and was unopened. I have put it in both of my bikes, one a high revving modern race engine that gets some hard graft and I've had no problems. First time FFRR owner
Post #380280 1st Apr 2016 12:04am
Classic888
Many thanks to you all for the informative and jovial replies. I will use it in the differential. Bow down
Post #380290 1st Apr 2016 8:21am
It is a good question to ask. My 20 litre tub of gearbox oil has been sitting about for a few years, and I just bought 3 bottles of transfer box fluid given it is as rare as hens teeth. .
Post #380370 1st Apr 2016 7:55pm
