Home > Technical (L322) > TD6 WARM/HOT START PROBLEM... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
To start with (excuse pun) you need a new thermostat - hours of fun to fit
22nd Mar 2016 5:39pm |
rangeroveruk1 Member Since: 22 Mar 2016 Location: rugby Posts: 7 |
Hi Joe90 , as its my first post I will ignore the pun anyway that was going to be my next job .... What about removal of the EGR thermostat? |
22nd Mar 2016 5:48pm |
Probably best to look at replacing both 'stats while you are at it. My experience was that I sorted the main 'stat then a few weeks later was back to change the EGR 'stat. In terms of removing the EGR 'stat, my vote is against. But others have had some success. (I have however been running for several years without the "vicious" fan in place ) .
22nd Mar 2016 8:21pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
This should point you in the right direction http://www.fullfatrr.com/forum/topic33098.html Yesterday I couldn't spell Engineer... Today I are one!
22nd Mar 2016 11:46pm |
Ok latest update for anyone who may be interested.... replaced the fuel filter and the secondary fuel pump... Car seems fine!! But.... I did notice what I can only describe as "air leak" noise coming from the area of the fuel filter and the high pressure pump.. I can't pinpoint where it is coming from, it's there when you turn the ignition on I guess something to do with the fuel lines being pressurised, but no fuel leaks! any idea?
27th Mar 2016 3:04pm |
Did this fix the temperature gauge issue too ?? .
27th Mar 2016 3:45pm |
Is your "Air Leak" the EGR by pass / blank? only its right in the area that you say the noise is and it has been disturbed recently Yesterday I couldn't spell Engineer... Today I are one!
27th Mar 2016 9:56pm |
Thanks for the reply but it's definitely not the egr blank as I can hear the noise when the engine isn't running , just the fuel pump priming |
28th Mar 2016 7:47am |
Are you sure that it's engine related and not the FBH, they can make lots of whistling whooshing sounds, and can come on at anytime. Although it's not that exact area of the engine bay it is the correct side of the car, and could be doing a first class ventriloquists act of throwing the sound Yesterday I couldn't spell Engineer... Today I are one!
28th Mar 2016 8:37am |
reidy99 Member Since: 27 Feb 2016 Location: suffolk Posts: 5 |
I am having the same problem replaced the high pressure pump and it was OK now 2 weeks later the problem is back but worse than before any other ideas to try? |
1st Apr 2016 6:32pm |
