Home > Maintenance & Mods (L322) > 2004 Brake Shield Fixable?
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Hi all,
My drivers side brake mud shield is now lose and wobbling around and causing pedestrians to wonder what the hell has just driven past. The mechanics have told me that to replace it is a major job (£300 inc labour) as the hub and bearing needs to be removed. They advised I could just cut it off from behind and not replace it. On the newer L322s the shield is a different design allowing easier removal without touching the hub.
I have read that some on here are using washers to help secure it again around the worn bolt hole but before I get the wheel off is this an easy fix for the early L322s. Would I need to remove the callipers etc to get to the securing bolts?
Any help greatly appreciated. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #379200 24th Mar 2016 12:18pm
few suggestions here,
http://www.fullfatrr.com/forum/topic4350.h...ake+shield ... - .- -.
Post #379206 24th Mar 2016 12:26pm
Very simple if I remember , look round the back of the shield and see the bolts just remove the bolt and put a big penny washer on it and re-fasten . 2008 MY Supercharged
Post #379207 24th Mar 2016 12:29pm
Flashman
Thanks guys, I will pop the wheel off and dig out some washers! Tom
Current Drive
Previous Drives
Post #379213 24th Mar 2016 12:39pm
Even easier, rip the rest of it off and throw it in the bin..... first thing I do to all my off roaders, makes no difference to the braking ability and to me is nothing but a win win situation..
You don't get stones stuck in it and you don't get a build up of mud (if you off road it) or silt (if you don't) which always rot the back of the disc out first...
Every car I've had has rotted the back of the disc out first, and I'm convinced it's because it doesn't get cleaned by spray etc like the other side of the disc does.... Thumbs Up Thumbs Up Pete
Post #379223 24th Mar 2016 2:04pm
Flashman
Interesting point and something I will do if I cannot secure it easily with a washer, a lot of people on various forums say the shields don't really do much (many cars don't have them from factory) and surely if the disc is better protected with it then it should have a shield on both sides! Tom
Current Drive
Previous Drives
Post #379231 24th Mar 2016 3:49pm
Brian
A well timed post. I have had problems with mine and after reading above (and a quick google) it seems they are really surplus to requirements so I will simply not replace them when I put the new disks and pads on. Also, therefore saving myself quite a bit as they are not cheap!
Post #379268 24th Mar 2016 10:06pm
Not only are they not cheap but they're a pain in the ass to replace as the entire hub has to be stripped off to change them
Post #379277 24th Mar 2016 10:54pm
Flashman
All bolt fixing areas were totally shot and it looked like a complete pain even to add washers so I just tin snipped it off and now there is no rattle. Will do the other wheels as and when they need it. Tom
Current Drive
Previous Drives
Post #379363 25th Mar 2016 3:17pm
You can't remove the rears on an FF, the shield is the backing for the handbrake shoes, they rust out to and are NOT a DIY job to change, you need the driveshafts out and the hub apart, chances are it will destroy the bearing and you need a special tool to get the drivshaft back in... Rolling Eyes Thumbs Up Pete
Post #379366 25th Mar 2016 3:38pm
Flashman
Good to know Pete. Fingers crossed they have some life left in them.
Tom Tom
Current Drive
Previous Drives
Post #379470 26th Mar 2016 10:10am
