Home > Technical (L322) > Detachable Lowball Stuck |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
It might just be me, but tried to take it off and no go, put key in, turn key turn black knob all the way and pull down it does not move, any ideas?
22nd Mar 2016 9:24am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi
22nd Mar 2016 9:35am |
blow lamp and lube it is at lunch time oh and a big hammer, i have a new cover from Dan and will keep it clean once its out |
22nd Mar 2016 10:42am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1372 |
The moving parts do tend to seize, especially if left in the socket for long periods. The sprung prong at the back (not sure what it is called) seems to get clogged with dirt and benefits from cleaning and lubrication. Perhaps removing the holder from the armature might give better access for cleaning and for allowing penetrating oil to run into it. Only Range Rovers since 1988 |
22nd Mar 2016 12:01pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
Removing from the armature is a good option - provided that's not also seized.
22nd Mar 2016 2:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8499 |
you don't just turn the knob you need to push it in and turn it at the same time.
22nd Mar 2016 4:48pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
you should be able to remove the pin/bolt from the whole slot-in 'unit' and get the hook, and socket onto a bench........and then resort to the big ol' hammer!
22nd Mar 2016 6:02pm |
gbmud Member Since: 19 Feb 2016 Location: Sussex Posts: 19 |
There is a key? I removed mine whole to fit a higher drop-plate type hitch but did not notice a keyway on the removed unit, nor do I have any key that might be the right one - I only got car keys with the vehicle.
24th Mar 2016 10:04am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Im sure you pull the black knob NMJ sir NOT push it... Just for clarities sakes |
24th Mar 2016 10:12am |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
Found my key in the tow ball stowage it's small with a red cap on it ,I would imagine it's easy to lose L322 2008 vogue R53 Cooper S Works tuned beyond the works SOLD R33 Nissan Skyline in rebuild 400bhp atw |
24th Mar 2016 10:54am |
to clarify, the different types of towbar, and with pictures.
24th Mar 2016 12:34pm |
I stand corrected, could be pull, it's that long since I've taken the tin tent out i can't remember!! There is nothing that can't be fixed with a hammer😜😜
24th Mar 2016 1:45pm |
The piece with the turning wheel that pulls out and turns to remove the detachable tow hook and then stays in the 'out' position until the hook is restored to the holder, when it snaps back and can be locked with the red-topped key, is also prone to seizing and benefits from being lubricated and turned/pulled etc until it all works freely. I'd spend time on that before using big hammers - the fixed hook is designed to hold 3.5 tons and I expect it won't budge easily when locked in position.
24th Mar 2016 2:45pm |
